  • New Member
  • Member For: 5y 2m 5d
Ok guys need abit of advice , I have a 420 kw xr6 turbo bf ute ...with a stock driveline and suspension set up , I’m looking at changing shocks but I’m not sure which way to go , pedders offers a few different types, but I’ve been put onto billstein by a suggested tyre shop who sounded very genuine , the billstien 2 way adjustmentable shocks are Nearly triple the price of the pedders brand at 5.5k ,  I’m just wondering what you guys have done to gain traction ... a coil over conversion is very costly , so I’m wondering if it’s worth it too put 4 link in, coil over conversion ? Or go with a custom leaf spring and adjustable shocks ... aim is to get 10s down the quarter , but still be able to take it sideways on track days like power cruise if possible
  • XR50T
  • Member For: 12y 6d
No need for a 4 link
Stock rear leafs. Shockworks front coilovers, rear adjustable dampers.
Then either a set of caltracs or Mal wood tramp rods.
If you go with the caltracs you can fit a rear sway bar.
  • XR50T
Tell them what you want.
Either way they only offer one rear damper for the Ute, the front coilovers comes with a 9kg/mm spring Wich rides firm yet is very comfortable.
Another set of springs for the front are under $150 elsewhere if you want to go with heavier front springs.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 27d
Any suspension shop or do it yourself. Installing struts isn't an overly difficult mechanical job. Setting them up correctly in terms of hardness and height is something that'll be unique to how you want your car to behave, but you can go with the recommendations of the manufacturer.
