Shake-xrturbo New Member 2 Member For: 5y 4m 4d Posted 28/02/20 10:04 PM Share Posted 28/02/20 10:04 PM Hi guys. I am wanting to put an aftermarket fuel pressure reg on my BA XR6 turbo and was wondering if the stock one comes out and generally just after some info from anyone that may have done it before. Thanks 👍🏼 Link to comment https://www.fordxr6turbo.com/forum/topic/95535-fuel-pressure-regulator/ Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 10d Gender: Male Location: Canberra ACT Posted 28/02/20 11:13 PM Share Posted 28/02/20 11:13 PM It is just held to the fuel rail with a circlip. Is pretty easy to pop off and just need to remove the vacuum line from it. Might need to get the crossover out of the way too on a BA. Bit fiddly to get to but if you are removing the fuel rail too it is a piece of cake.If you do remove the rail (eg if you are upgrading injectors) it is a piece of cake. Remove the fuel supply and return lines at the quick connects under the car to make it easier.If your new reg has different pressure to factory, you will need your car tuned for that. What's the reason for wanting to replace it? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95535-fuel-pressure-regulator/#findComment-1692608 Share on other sites More sharing options...
