Barra31 New Member 10 Member For: 5y 3m 2d Posted 10/02/20 09:13 AM Share Posted 10/02/20 09:13 AM R31 Barra project thread Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 2d Gender: Male Location: Melbourne Posted 10/02/20 09:32 AM Share Posted 10/02/20 09:32 AM looks like it should be a very fun project Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692225 Share on other sites More sharing options...
Barra31 New Member 10 Member For: 5y 3m 2d Posted 10/02/20 09:57 AM Author Share Posted 10/02/20 09:57 AM Well, after typing a super long introductory post I have accidentally deleted it whilst trying to upload images, so please excuse me for the poor grammar and rushed post. So, lets start again, long time lurker here, have finally decided to join the forum. For a long time I've had this ridiculous obsession with R31 Skylines, I've had this particular 31 sitting around for years now that somewhat has some sentimental value and figured now is a better time then any to start making a move on it. Late last year I had my eye on a 2UR-FSE (For those that don't know, it's a Toyota quad cam 5.0 V8 out of an ISF) with an 8 speed transmission, This was a month or two out from my wedding and unfortunately priorities got in the way (which absolutely sucked, but hey lets keep that to ourselves, she doesn't read these forums!). I did during this time happen to however come across a super cheap FG XR6T manual motor complete with ECU and Harnsess around 80-90km's. The initial plan was to split it open to check condition (car had been in a hard front ender), Check pump backing plate and gears being a manual motor (plus billet gears) and throw some bearings in it. I figured, factory turbo, a stock ZF and 300 odd rwkws in a 1300kg car would be enough to stain the seats but we all know how that story goes. Everything was good and would have been fine, but as it goes every single time, There was a voice whispering quietly in my ear "why not while it's apart, you'll break it and do again anyway", so here is the list so far. Engine so far - Cleaned factory FG XR6T pistons Fresh hone and new rings with opened up ring gaps Spool H-beam rods XR6 Turbo developments billet oil pump gears ARP Main Studs Plans ahead - 10mm alloy girdle - wanted some opinions on this, is it worth the girdle, are we able to fit factory windage tray with a 10mm girdle ARP Studs and a factory BA Sump ? Mace timing chain kit Factory Ford head gasket Crow Cams valve springs with factory retainers Deck head Valve stem seals GT3884 on stock manifold 1000cc injectors Front mount (I'd also like to try and retain power steer and a/c) Possibly HP Tuners NGauge, any opinions on this, are we able to run FLEX with these ? Driveline and Suspension - 31 spline mechanical LSD centre 31 spline billet axles Boxed rear arms Stock springs with new shocks all round Thicker rear sway bar Custom front sway bar to clear sump R33 twin piston front calipers Re-sealed standard rear calipers with 300mm EF rotors Nissan RE4R03A ( these seem to hold up in Patrols with small mods, hoping the same will apply for something around a tonne lighter) Valve body Stall converter Single piece tail shaft Not sure what realistic power figures would be with this but am hoping for a 10 second capable car that can drive 500km's up the coast without a worry Love to hear what you guys think! Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692227 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 2d Gender: Male Location: Melbourne Posted 10/02/20 12:12 PM Share Posted 10/02/20 12:12 PM looks like you've got yourself going right down the right track fantastic looking engine and build progress update I'm not sure on the girdle, but while you're there it's always worth upgrading. I believe PCMTEC tuning software can do flex, but not 100% sure... @rollex can confirm. Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692235 Share on other sites More sharing options...
Barra31 New Member 10 Member For: 5y 3m 2d Posted 11/02/20 10:31 AM Author Share Posted 11/02/20 10:31 AM Thanks @k31th looking forward to getting stuck into it! I think I will go down the path of the girdle, although I may need to trim the FG windage tray to suit the BA/BF sump. I'll definitely look into that, I still need to look into engineering, ideally I'd like it to make the power on pump but I'm thinking IM240 might be a little easier to pass with some ethanol on board. Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692256 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 2d Gender: Male Location: Melbourne Posted 11/02/20 10:31 AM Share Posted 11/02/20 10:31 AM engineering is a tricky prospect... Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692257 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 4d Gender: Male Location: Australia Posted 15/02/20 05:34 AM Share Posted 15/02/20 05:34 AM (edited) Flex fuel is totally possible. About ~$1k for a plug and play loom, sensor and fuel rail fittings (assuming you are using the stock fail). Speak to Danny and he can sort you out with the right kit depending on which ECU and loom you are using. https://www.facebook.com/pirottaperformance If you need to pass emissions it will be much easier with the stock ECU, send me a PM and I can recommend a tuner who knows what they are doing and has the time to sort that out for you. It will be very easy to meet the RB30E emissions if you put a modern factory catalytic converter on a barra. Edited 15/02/20 05:36 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692349 Share on other sites More sharing options...
Barra31 New Member 10 Member For: 5y 3m 2d Posted 23/02/20 10:43 AM Author Share Posted 23/02/20 10:43 AM Thanks Rollex, PM sent. Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1692498 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 7y 3d Posted 30/04/21 12:36 PM Share Posted 30/04/21 12:36 PM Hows this going? I did a bf na barra n zf into r31 recently. Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1704453 Share on other sites More sharing options...
Barra31 New Member 10 Member For: 5y 3m 2d Posted 29/06/21 11:49 AM Author Share Posted 29/06/21 11:49 AM Hey mate, sorry, hopeless at checking and updating this thread! The motor is still currently sitting on a stand pretty well assembled (needs sump & timing cover on) haven't added anything different other then cams, I'd love to use a ZF but the cost factor would be killer considering wanting to make 4-450 rwkw. How was tunnel space with the ZF ? Do you have any other details or images of the car at all ? RB is practically out just waiting on some storage space, really need to give myself a kick to motivate me to hurry up and move forward with this thing. Link to comment https://www.fordxr6turbo.com/forum/topic/95502-rebuilt-barra-r31-project/#findComment-1705773 Share on other sites More sharing options...
