J.thorne94 New Member 2 Member For: 6y 2m 18d Posted 10/02/20 05:16 AM Share Posted 10/02/20 05:16 AM Hey people, I have a 2007 MK2BF, everything is stock. I noticed my car lacking power and could hear a boost leak. Inspected all boost pipes, found pipe on the front of the turbo had come off. Re fitted and tightened, and test drove. Can hear turbo spooling but still has air / boost leak. Turned out my waste gate actuator was faulty. I replaced the actuator and test drove again. Now I cant hear or feel the turbo spooling, but it was before I changed the actuator. Anybody have an idea what the issue could be? Another faulty actuator? Blocked Cat? Thanks in advance Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,382 Member For: 16y 11m 29d Gender: Male Location: Melbourne Posted 10/02/20 06:30 AM Share Posted 10/02/20 06:30 AM try connecting the front nipple of the turbocharger directly to the wastegate nipple and that'll tell you if you've got a physical problem with the wastegate or flapper if the problem remains, otherwise it'll point to a problem separate to the boost control (e.g. a leak). If it doesn't make 8ish psi connecting like that it'll be a boost leak etc. Link to comment Share on other sites More sharing options...
J.thorne94 New Member 2 Member For: 6y 2m 18d Posted 12/02/20 01:39 AM Author Share Posted 12/02/20 01:39 AM Hey mate, did what you said. Actuator was fine. Pulled out my cat to have a look coz I couldnt find a boost leak or any other issues. Cat was blocked. Knocked it out and now she boost killer. Gonna upgrade my exhaust. Can you recommend a exhaust and Cat? Cheers mate Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,382 Member For: 16y 11m 29d Gender: Male Location: Melbourne Posted 12/02/20 02:06 AM Share Posted 12/02/20 02:06 AM well, if you've knocked out the contents of your cat, then that's the main restriction in the exhaust and it might even overboost now and you'll need a tune to suit any major changes to the flow of the exhaust... so whatever style exhaust you like you can get or you can stick with what you've got and get it tuned to suit the empty cat. Link to comment Share on other sites More sharing options...
