ALADE New Member 11 Member For: 5y 4m 12d Posted 27/01/20 02:50 AM Share Posted 27/01/20 02:50 AM 2013 FG XR6T auto Well guys I am a new member here I absolutely love this FG I have brought what a great car I am currently doing mods and am after advice on a few things Firstly I have put in a intercooler and air intake on the turbo side it is booked in this week to get a exhaust at Kuluin mufflers on the sunny coast 4" dump Hi flow cat and 3 1/2" from there , my question is do I need a tune directly after this work? The last thing I want to do is put in some new injectors and get the tune ( who on the sunny coast or Brisbane is good tuning these beasts?) What power will this set up make ? Thanks Andrew Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/ Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 9m 4d Posted 27/01/20 02:57 AM Share Posted 27/01/20 02:57 AM Baby turbo will limit you at around 300rwkw, reliably.You can make up to 320-330rwkw on 98 pump fuel with baby turbo but that is ringing the balls of it and it'll go pop soon.290-300rwkw is what to expect from your mods. On 98. Reliably. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691916 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,537 Member For: 17y 1m 29d Gender: Male Location: Melbourne Posted 27/01/20 03:01 AM Share Posted 27/01/20 03:01 AM yes, you will need a tune with changing the cat and you'll definitely want injectors put in by your tuner. if you want to find a good tuner, read about the QLD ones in this thread-> https://www.fordxr6turbo.com/forum/topic/83001-tuner-in-queensland/ 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691917 Share on other sites More sharing options...
bupalooga Silver Donating Members 262 Member For: 12y 8m 2d Gender: Male Location: Griffith NSW Posted 27/01/20 07:01 AM Share Posted 27/01/20 07:01 AM Once the dump & cat goes in only drive it lightly off boost to get it to the tuners or sh*t can go bang. Get the tuner to install the injectors when you take it in. I got 300kw on near identical mods. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691924 Share on other sites More sharing options...
ALADE New Member 11 Member For: 5y 4m 12d Posted 28/01/20 11:32 AM Author Share Posted 28/01/20 11:32 AM What about the x4 flash tuner you can get with injectors for about $1500 is this a good option or are you better getting a Dyno tune ? Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691944 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,537 Member For: 17y 1m 29d Gender: Male Location: Melbourne Posted 28/01/20 11:38 AM Share Posted 28/01/20 11:38 AM the X4 flash tuner allows many tunes to be put onto your PCM/TCM, it's not hte "tune" itself. you need a "custom dyno tune" to go in any one of those "tunes" (different fuels, different boost settings etc you can choose to have tunes for if you so desire, but of course it'll cost more). There's other software that doesn't require a handheld device like the X4 that puts a tune directly onto your PCM/TCM without the device itself but of course you can't switch tunes like you might want to with a device. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691945 Share on other sites More sharing options...
MaStars Donating Members 81 Member For: 8y 3d Gender: Male Location: The Gap, Brisbane Posted 28/01/20 11:30 PM Share Posted 28/01/20 11:30 PM On 28/01/2020 at 11:32 AM, ALADE said: What about the x4 flash tuner you can get with injectors for about $1500 is this a good option or are you better getting a Dyno tune ? Expand I would Highly recommend finding a Tuner that uses PCMtec. Apparently the SCT stuff hasn't been updated in years, yet PCMtec is still being developed here in Australia specifically for the barras. And now you can have up to 4 different Maps pre-loaded into the factory PCM that you can change between while driving. IMO the SCT and HP tuners is outdated and a waste of money for a hand-controller considering what the PCMtec can do. 3 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691946 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 7y 30d Posted 29/01/20 04:06 AM Share Posted 29/01/20 04:06 AM (edited) You may wish to decide on how far you wish to go with the car, as you may be tumbling down the rabbit hole. You may wish to consider having the flapper mod done, or installing an external wastegate. Larger exhausts on these things do help them to over boost significantly. as said before once the exhaust is fitted, only drive it off boost and resist temptation to give it the berries. Pre tune you will also want a fuel pump installed. walbro 255 upgrades dont generally require much work or changes to your fuel regulator. higher flow pumps will need wiring updates, as they require more amps and your pressure regulator will require changing as they cant dump enough fuel that the bigger pumps send. GFB now make a drop in fuel pressure regulator that's suited to the task. ideally have it tuned not long after exhaust install, with injectors of your tuners choice, some tuners have injector preferences. your tuner will use whatever method they prefer to tune the car, but I do agree with MaStars regarding PCMtec, they are an Australian company so its great to support them as they are working hard to make the falcons do wonderful things on the stock ecm. with all these things you will be set for a fun time, I would also suggest an external cooler for the transmission but its not necessary before tune just recommended for longevity of the transmission. Edited 29/01/20 04:08 AM by BeerTurbo cant spell. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691948 Share on other sites More sharing options...
ALADE New Member 11 Member For: 5y 4m 12d Posted 30/01/20 01:29 AM Author Share Posted 30/01/20 01:29 AM Yep thanks beer mate I was lucky enough to buy the car with an external cooler already on he said it cost him $800 I think he said PWR brand or something like that it look good quality it’s in today for the exhaust and I managed to find a tuner a mate who has fast cars put me on to him Scotty Hoffman he’s in Brisbane so it’s book with him next week thanks from the rest of you guys helping out Link to comment https://www.fordxr6turbo.com/forum/topic/95471-exhaust-and-tuning/#findComment-1691974 Share on other sites More sharing options...
