Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 11/01/20 11:55 PM Share Posted 11/01/20 11:55 PM So stock with a k&n panel in standard airbox made 258rwkw and now iv done atomic valve springs, atomic tool steel head studs with oversize washers, atomic new forged oil pump, pw stg 2 ic, 3582 Garrett turbo with .70 comp housing, turbo smart external gate plumbed back in under car, 4 inch steam pipe dump, no cat, 4 inch exhaust up to 3inch flange under the car, 1050cc injectors, kpm 700hp intank pump with higher flow fuel regulator, breather and pcv holes drilled out to 14mm and no pcv now, both pipes go to a catch can that breathes to under the car so no fumes coming into cabin, intune motorsport ic piping kit that had to be modified to fit, stock crossover with muffler delete and airbox with k&n panel. 50mm hole drilled in front bottom of airbox. B&m engine and trans coolers mounted behind right side fog light, fogs taken out and mesh put in hole, derale sandwich block with thermostat to plumb engine oil cooler. Car made 414rwkw at 18psi on dynapack hub dyno but we pulled it back to 15psi 382rwkw to be kinder to driveline and pistons, I love how it goes now, lights up the tires in 2nd gear in dry, it is almost as quiet as stock on cruising and sounds boss when boosting, I might do the ims twin Bush diff hat next. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/ Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 07/06/24 01:29 AM Author Share Posted 07/06/24 01:29 AM Got my fgx tuning finished, and it is pretty darn good. 445kw. 867nm torque, 20 psi boost, drives perfectly, still has stock 3 inch exhaust and stock mid and back mufflers, but 4 inch dump and 50mm ts gate plumbs in under car. Car is very fast and hooks up good, 3rd gear sees 15psi by 3100 ish rpm and 17ish psi by 3500, 4th gets 20psi at around 4000 I think. On dyno from 5k to 6k rpm boost dropped from 20 to 16psi and duty cycle was at 100% and tuner couldnt get boost to hold 20 up top despite having gate plumbed to top and bottom ports. I do have 4.6mm id push lock air lines and stainless fittings for wastegate and solenoid plumbing and I was wondering if that size tubing could be a bit large and there is no restrictor pills in line. Also I was wondering if the stock 3inch exhaust could be preventing it from getting 20psi over 5k revs. On the dyno we could hear it change sound over 5k when boost dropped to 16psi. Im not worried because on the road when it gets to 5k revs its going so fast it doesnt matter. The Artec manifold and efr 9174 seems a nice combo for drivability and power. I like it alot. Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723163 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 18/06/24 09:27 AM Author Share Posted 18/06/24 09:27 AM 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723286 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 18/06/24 09:47 AM Author Share Posted 18/06/24 09:47 AM My build, efr9174 turbo, t4, 1.05 split pulse, Artec stainless investment cast manifold, stainless studs, atomic anchorlox manifold and turbo fasteners, custom heatsheilding made by me protects power steer res, sensor on back of head coolant res, heater hoses, engine mount, p steer lines, keeps heat in manifold and protects bonnet, custom 4 inch steampipe dump made by me, rubber heater and water hoses custom tucked in tighter with 90 bends and a stainless bend to get them in by firewall and away from dump pipe, ts 50mm gate plumbs into 4 inch exhaust under car, then stock 3 inch with stock mid and rear mufflers. Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723289 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 18/06/24 10:02 AM Share Posted 18/06/24 10:02 AM Make him a thread @k31th Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723290 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,410 Member For: 17y 7d Gender: Male Location: Melbourne Posted 18/06/24 10:09 AM Share Posted 18/06/24 10:09 AM merged those posts into one of your old threads use this one for all your "car" updates have also moved it over to the 400+ section and renamed it 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723291 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 18/06/24 10:11 AM Author Share Posted 18/06/24 10:11 AM Cheers @Puffwagon I think this will be the last incar-nation of my fgx for a long time. Im pretty stoked with how it worked out, I took my time and tried to do it all to a decent standard and didnt cock anything up which was satisfying. I learnt alot too. Also under bonnet has maximum street cred now lol. I learnt that saying off one of the blokes on this forum. Thanks @k31th that's awesome. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723292 Share on other sites More sharing options...
Tom Tucker Donating Members 701 Member For: 5y 9m 17d Posted 23/06/24 11:16 AM Share Posted 23/06/24 11:16 AM Love the combo @Slowxr6t. Congrats on the results! Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723371 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 25/06/24 08:01 AM Author Share Posted 25/06/24 08:01 AM @Puffwagon regarding my boost drop at 5000rpm from 20 to 16psi. Do you think my 3 inch stock, 4 inch dump back exhaust could be causing boost to drop off quickly? Its hitting 420kw at 5000rpm on dyno graph and rising to 440 at 6k with 16psi from 5-6 k rpm There must be a limit a 3 inch can flow but could it restrict boost?? Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723389 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 25/06/24 08:27 AM Share Posted 25/06/24 08:27 AM It would pick up boost with a 4 inch dump pipe, but I suspect yours might be needing more gate spring, providing the boost control is actually delivering 100% wgdc as you previously mentioned. You'll want 12psi of spring, give or take, to make 20psi on your setup. I've put over 20psi with a stock territory exhaust (they are mostly 3 inch) so I don't think yours is restricting it in that sense. Link to comment https://www.fordxr6turbo.com/forum/topic/95431-382rwkw-fgx-xr6t/#findComment-1723391 Share on other sites More sharing options...
