New here, what sort of power should reach
Ole1985
  • New Member
  • Member For: 5y 1m 26d
2012 fg turbo Ute manual
4 inch x force exhaust
stage 3 process west cooler
process twin west surge tank
1000 injectors
Walbro  525 in tank
garrett gtx3584 gen 2
Battery relocation
external wastegate turbo smart 60 mm screamer pipe
flex fuel sensor
oil pump gears
valve springs
atomic chain set
new head gasket
I know I didn’t do conrods and pistons but it’s a future project including a t400
also do you remember replacing  my ecu now or wait until further mods, will I get advantages of doing it now
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 21d
:Welcome2FordXR6t:
you can probably get into around 400-450rwkw with those mods. injectors are the weak point for further power goals.
you don't need a flex fuel sensor if you're sticking with the stock ECU as you'll get an E85 tune or a 98 tune or in between the two at a specific ratio of the two... and you don't really need to replace the ECU at all as that's only for the most extreme of applications or specific goals.
the 60mm wastegate is also large for the specific setup you've got, but no big deal there as it'll control boost still.
  • Dropping a turd
  • Member For: 17y 4m 4d
1000 injectors
Walbro  525 in tank
Battery relocation
flex fuel sensor
oil pump gears
valve springs
atomic chain set
new head gasket
Good mods, especially flex fuel. Change the 1000 to 1300 or 1700. Tell the tuner your final power goal and he will advise on which to get. With those mods and E85 you will go close to 500rwkw. Bigger injectors will push it further. If you are changing head gasket may as well change head studs.   factory ecu is fine.
Stage the surge tank pumps with pressure switch (hobbs switch).
Edited by arronm
  • Member For: 18y 9m 6d
5 hours ago, Ole1985 said:
I wasn’t do you recommend it what are the advantages
I guess that it depends on how much power you're chasing,   driveability, lag and how long you want to keep a stock bottom end together...
Power is cheap. Reliability is expensive.
