Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 22d Gender: Not Telling Posted 02/04/21 10:25 AM Share Posted 02/04/21 10:25 AM On 02/04/2021 at 10:07 AM, violetpop said: One minute its had an easy life in a ba wagon, next minute Expand On 25/08/2020 at 7:30 AM, Puffwagon said: Yerp that will give you part of a stock rebuild. I looked at this option and then I thought well fark if I'm going to spend $500 on pistons I may as well spend enough and get some forged pistons, then I thought well fark it, I'll get upgraded pins too then I thought fark it and got I beam rods too. While it's out and apart; You'll want better rods too, so they'll need sizing and the crank will need linnishing, then you may as well get oil pump gears, then you may as well get main studs which will mean line honing, and if you're getting it line honed then you may as well get a girdle and get the main caps machined to suit, then you may as well do the flex plate cos you may as well while it's out, then you'll want to at least deck the head, then you may as well get the seats re cut while you're there and get a decent set of springs in it, so you may as well get a full atomic timing kit, and of course you'll be forking out for a full vrs kit which will mean that you may as well get a better head gasket, then you may as well get head studs too cos it's only an extra $250, then you may as well get a balancer cos the stock ones are sh*te, then for all that bullsh*t you may as well buy a giant turbo and if you've got a giant turbo then you'll need a beastly fuel system and then you'll put the whole lot together, break your transmission, replace that, break the diff, replace that, go through a set of tyres and axles every 2 weeks and eventually wish that you'd just bought a honda civic and paid off the mortgage instead. But yeah, nothing wrong with a stock rebuild Expand NEK MINUTE Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703765 Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 16y 13d Gender: Male Location: Brisbane Posted 02/04/21 01:44 PM Share Posted 02/04/21 01:44 PM The standard head gasket is completely fine for a LOT of horsepower, the only reason I would 'upgrade' that gasket from a standard Ford gasket would be to do fire rings, otherwise the only upgrade needed on the head would be the studs themselves. I feel like I have proven the standard gasket goes pretty well throwing 40 plus psi at it without any issues. Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703771 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 14d Posted 03/04/21 11:15 PM Author Share Posted 03/04/21 11:15 PM Got the rest of the car back together last night and went for a successful road test! Got the cooling system sorted first and got the pressure tester on it while I was doing other things. No leaks! Could it have just been the gasket? Maybe... The car didnt miss a beat on the easy going hour long road test and only time will tell if things hold up. plan is to check things over today and see how everything looks. In the next week I aim to get a new radiator in it and I've also ordered the thermostat housing bleeder for quicker fill ups.Dominator also supplied this spacer type plate which looks to go above the timing cover but I didnt see a need for it as the surfaces were dead flat.I hope the engine is now reliable to have it on the road long enough to smash an axle. 4 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703791 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,510 Member For: 17y 1m 12d Gender: Male Location: Melbourne Posted 03/04/21 11:19 PM Share Posted 03/04/21 11:19 PM good result that blue background of your engine bay is so striking when you compare it to exterior colour haha 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703792 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 14d Posted 04/04/21 12:48 AM Author Share Posted 04/04/21 12:48 AM Its just a mash up of colours that don't really work. Certainly won't be winning any show and shine awards. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703800 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 22d Posted 04/04/21 04:02 AM Share Posted 04/04/21 04:02 AM Top effort man 👍 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703809 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 14d Posted 04/04/21 07:06 AM Author Share Posted 04/04/21 07:06 AM Cheers mate! I still would have felt much better to pressure test the head and know for sure its all good. I will see how this holds ups for now. Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703824 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 14d Posted 04/04/21 10:06 AM Author Share Posted 04/04/21 10:06 AM Been researching radiators and for a good reason. It appears someone has fitted an early ba possibly xt radiator at some point. I've driven the car again and gradually increased the boost. The car rips but it rips to the point where I think its over boosting. Blew the hose off the throttle body twice but getting on it, it starts to turn the tyres so easy in second which it didnt do before.A minute from home, the radiator top hose outlet gave up and the temp started to shoot up just as was coasting into the drive way. Managaned to cool it down pretty quick but what a frantic minute it was. Big fail.. So looks like new rad will be happening sooner rather than later and then move on to working out where all this crazy power has come from. Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703835 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 21d Gender: Male Location: Brisbane Posted 04/04/21 10:17 AM Share Posted 04/04/21 10:17 AM 400rwkw will spin up easily in second. Was the dyno sheet from its actual last run on the dyno. I'd say that's when the problem started and we all know how bike riders like to limiter bash all the time 😁. You might have been down on power when you picked it up and just got worse over time. Is it pinging, have you got a boost gauge on it? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703836 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 7m 14d Gender: Male Location: Mildura Posted 04/04/21 10:22 AM Share Posted 04/04/21 10:22 AM @violetpop Fenix sell a 50mm aluminium radiator for $440, maybe that's worth a try? Or the standard BA/BF XR6 turbo radiator should be 26mm but we sell a 26 and a 32mm thick core from either Adrad or Motogear. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/56/#findComment-1703837 Share on other sites More sharing options...
