violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 12/05/20 10:37 AM Author Share Posted 12/05/20 10:37 AM Thanks mate I will give them a call.. I see GCG sell them for ba bf and fg https://gcg.com.au/G445963-0151.html?ref_cat_id=152 https://gcg.com.au/G445963-0135.html?ref_cat_id=152 Was yours cheaper from mtq? Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694695 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 21d Gender: Male Location: Canberra ACT Posted 12/05/20 10:51 AM Share Posted 12/05/20 10:51 AM Yep MTQ was about $200 delivered. Ask about the spring pressure, but should be the FG one you are after. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694696 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 12/05/20 10:59 AM Author Share Posted 12/05/20 10:59 AM I will talk to them for sure. I suspect I could use either one but if I use the fg one a tune will be needed which is already part of the plan anyways. *I should say I was thinking fitting the fg actuator before the tune could send the ecu loopy but not 100% sure Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694697 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 21d Gender: Male Location: Canberra ACT Posted 12/05/20 11:12 AM Share Posted 12/05/20 11:12 AM Yep you might hit the overboost threshold on a B-series and the wastegate maps would be a bit out.As a rule of thumb you can generally tune for double the boost of your wastegate spring. So if a B series spring is 5psi or something you will be limited to about 10. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694698 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 16/05/20 05:32 AM Author Share Posted 16/05/20 05:32 AM Good to get back in the garage and get stuck into it.Turbo and manifold pulled off today in prep for porting and fg turbo. Found it much quicker to pull the manifold off along with the turbo in one hit. Saved a stack of time, did everything from the top.Plan is to get the rear housing to cms and get the port job done, new actuator and perhaps assemble everything while they have it and get it all ready to bolt back up. Might add some new studs and lock washers for good measure perhaps.Putting the 16" steel wheel failure behind me I got some colour and clear on the Ghia wheels. Turned out pretty good I reckon.Fellas you think its worth ceramic coating the rear housing and manifold while its off? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694793 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 3d Gender: Male Location: Melbourne Posted 16/05/20 05:43 AM Share Posted 16/05/20 05:43 AM nah to ceramic coating... otherwise the wheels are looking good 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694794 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 16/05/20 05:45 AM Author Share Posted 16/05/20 05:45 AM Save a few bucks then happy days! Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694795 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 19/05/20 09:11 AM Author Share Posted 19/05/20 09:11 AM Managed to separate the rear housing after letting it sit in a bath of inox, came loose pretty easy. Port job coming! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694885 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 3d Gender: Male Location: Melbourne Posted 19/05/20 09:22 AM Share Posted 19/05/20 09:22 AM haha a bath of inox... that's an interesting way to go about it... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694888 Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 5y 5m 5d Posted 19/05/20 09:30 AM Author Share Posted 19/05/20 09:30 AM Read a few articles on people having issues with seized housing.. Few of the bolts were actually hand tight. Got some nordlocks for the m10 manifold to turbo nuts and a stud kit too.I'm considering if this is a good time to buy a bolt in high flow cat considering the gate will be ported and tune up coming. Link to comment https://www.fordxr6turbo.com/forum/topic/95394-my-long-term-tidy-up/page/21/#findComment-1694890 Share on other sites More sharing options...
