DakotaWebber New Member 9 Member For: 5y 5m 2d Posted 29/11/19 03:19 AM Share Posted 29/11/19 03:19 AM Hi All, After swapping in a new transmission to my NA G6E, im going to get the trans shop to change the factory unit (which is what killed my last trans, woo hoo zf milkshake yo) to an oil to air cooler to prevent the chance of water getting in the box. Seeing as im N/a and dont thrash the life out of my box, would my temps be fine? are there recorded temps on the site that people have after a similar setup? should I install a thermo switch/fan in case im sitting in heavy traffic? I have an OBDII connector for my phone so I will try to find the trans temp PID (Torque Lite, does anyone know the details of this? should I get the paid version?) so I can hopefully monitor the temps, however I am confident in installing a temp sensor and or fan if need be myself. Thanks Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,277 Member For: 16y 10m 21d Gender: Male Location: Melbourne Posted 29/11/19 03:25 AM Share Posted 29/11/19 03:25 AM it'll be fine to put in basically any trans cooler setup. it won't need a fan as you won't be pushing the trans hard when you're sitting in traffic. have a read of this thread for the trans temp monitoring PID etc. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 4d Gender: Male Location: Perth Posted 29/11/19 03:46 AM Share Posted 29/11/19 03:46 AM Just stick the cooler in front of the radiator. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 10m 9d Gender: Male Location: Canberra ACT Posted 29/11/19 03:58 AM Share Posted 29/11/19 03:58 AM As a reference, I have a thermo switch on mine to kick in at 85 degrees, and a light to tell me when it does.In the past year, I reckon it has been on twice. Once on a 40 degree day after a long drive when I was circling the car park. The other was giving it a hard time in low gears through mountains on a warm day. But my car is turbo and modified, and the cooler is inside the bumper in front of the driver's side front wheel. And with the factory heat exchanger imagine you'd be seeing temps over that anyway.NA car with the cooler in front of the radiator - no worries at all with no fan. Link to comment Share on other sites More sharing options...
DakotaWebber New Member 9 Member For: 5y 5m 2d Posted 29/11/19 05:14 AM Author Share Posted 29/11/19 05:14 AM Cheers guys looking forward to the peace of mind Link to comment Share on other sites More sharing options...
