K4L4M1TY Member 32 Member For: 6y 3m 3d Posted 17/11/19 05:25 AM Author Share Posted 17/11/19 05:25 AM Yep, got it from autobarn because my buddies work there so discount and no fuss warranty but for now it should do. Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689949 Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 6y 3m 3d Posted 17/11/19 06:02 AM Author Share Posted 17/11/19 06:02 AM Next fun part is how much zf fluid I will lose/need to refill after new radiator is in, I have a couple of bottles of fluid for it and thinking I should go all the way and flush the zf at the same time. Fun job from what I've been reading. Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689950 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 1d Gender: Male Location: Perth Posted 17/11/19 06:58 AM Share Posted 17/11/19 06:58 AM Not a drop Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689952 Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 6y 3m 3d Posted 17/11/19 07:13 AM Author Share Posted 17/11/19 07:13 AM Wont the cooler in the radiator be holding fluid or at least some come out of the hoses when I disconnect them? Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689953 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 5d Gender: Male Location: Canberra ACT Posted 17/11/19 09:00 AM Share Posted 17/11/19 09:00 AM ZF doesn't have a cooler in the radiator Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689958 Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 6y 3m 3d Posted 17/11/19 09:31 AM Author Share Posted 17/11/19 09:31 AM So how does the 'milkshake' happen? Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689960 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 5d Gender: Male Location: Canberra ACT Posted 17/11/19 09:38 AM Share Posted 17/11/19 09:38 AM They have a heat exchanger that runs coolant through it, but is a separate component to the radiator. Sits off the side of the engine under the starter motor. Follow the lines off the transmission to find it.As luck would have it, here is a picture I took of mine on Friday, where it belongs!(I did an external cooler a while back, and finally unplumbed the heat exchanger from the cooling system as I was doing a coolant flush,) Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689961 Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 6y 3m 3d Posted 17/11/19 09:58 AM Author Share Posted 17/11/19 09:58 AM (edited) Ahhh so it runs coolant through that, I always assumed the trans fluid ran through piping in the radiator for cooling. Edited 17/11/19 10:00 AM by K4L4M1TY Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689963 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 5d Gender: Male Location: Canberra ACT Posted 17/11/19 10:21 AM Share Posted 17/11/19 10:21 AM The BTR 4 speeds did that, but not the ZF. So would be possible to buy a BF radiator with a trans cooler in it (to suit models with the BTR), which makes it confusing!If you bought one with transmission ports in it, just leave them disconnected. Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1689964 Share on other sites More sharing options...
Yalllowba New Member 4 Member For: 5y 5m 17d Posted 18/12/19 05:01 AM Share Posted 18/12/19 05:01 AM Just a question while you’s are on the radiator topic, will a bf radiator go into a ba, I was told they don’t Link to comment https://www.fordxr6turbo.com/forum/topic/95313-radiator-suggestions/page/2/#findComment-1690823 Share on other sites More sharing options...
