  • Member For: 7y 22d
Hay just wondering why every one says to build a ba engine to match or pass the specs is more expensive than just buying a buying a bag motor it only cost 750 for connecting rods to match 1200hp and 440 for valves that are top quality then the rest are basic Bolton’s the heads different but you just get more compression out of the ba
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 14d
Even the most basic Barra engine build to handle 400rwkw is around $4000 in parts and machining
Anything less and you’re not doing it right
Yeah probably if you have to pay for  labour it could still don’t know where you are but for me to get a half decent fg turbo front cut is around 2500 just purchase than transport 3000 then the small bits and pieces gonna cost that anyway may aswell build from inside out or buy a n/a block and building it from inside out
What are some brand names you would steer clear from when going for Conrods and is the crank the same through out and is it worth swapping out and if so any recommendations
  • New Member
  • Member For: 9y 26d
I have a BA xr6t, I personally think depending on your budget and what you want out of your car, if I could afford it I would like to build the original motor. 🙂
Lol well maybe youse it for helping instead of commenting stuff that just doesn’t really help that much it’s like talking to the riddler
Riddle me this riddle me that what mods will you do to make the crack ????
  • New Member
Yes you could buy a later upgraded spec motor and just boost it ECT, or have the enjoyment and satisfaction of working on and building your own motor! One of the best things imo is that you can save up and buy the pieces needed for the rebuild I.e ,rods, pistons, bearings, harmonic balancer, valve springs, and the like, then when you're ready pull the motor, have the head worked and fitted with the new valve springs, have the block acid cleaned and cylinder bores honed to specifications for the new pistons rods ECT. And have the knowledge of what's in your engine and what the parts are, and can handle power wise. But that's just my 2 cent's worth 🙂
