  • New Member
  • Member For: 5y 5m 7d
So basically I’ve just bought an XR6 Turbo ute, and it is written on paper as a BF MK2 but I just want to make sure as I have read there is quite a few differences between the 2... is there any key differences that I can check to 100% make sure I have a MK2?
Cheers in advance
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2d
:Welcome2FordXR6t:
a mkII badge on the back is the most obvious indicator.
I'd also ensure the engine number matches the VIN number and then the build date will tell you if it's for sure a mkII.
the only thing that matters is if it's built on or after June 2006 for the stronger motor, if power upgrades are what you're looking for.
  • New Member
This is the part where I’m a bit confused, my cars debadged so it doesn’t say MK2 on the back anyway (or XR6 Turbo or anything).
It hasn’t got lower side vents and on paper it says MK2 so it seems like it is a MK2 but the build from memory was 03/2006
Here’s the car
  • New Member
So I seem to have all the features of a MK2 but apparently built before they came out? Unless I’m reading something wrong
