Kickdown Into 1st Gear?
faygun
  • Member For: 21y 7m 11d
hey guys, I have always been curious about this. It might be a very dumb question but here it goes :thumbsup:
In a manual car, you dont down shift into 1st gear unless you just came to a full stop or rolling very slightly.
In an auto car, you can floor it when you are doing like 40-50km/h and it will kickdown into 1st gear. is this bad for the gearbox?
Thanks guys :thumbsup:
  • Replies 33
  • Member For: 22y 4m 12d
Nope ... go for it. There is also no reason you can't do it with a manual. Shift back to first at 40kph that is. The only difference is the gear ratios. With a manual you will run out of revs at about 55-60kph whereas the auto will run to over 75kph.
I knew you would reply quickly Turbo6man ;) thanks for the advice :D
I used to feel bad for my car when it kicked down into first when I was doing like 50 km/h.
I am very mechanically cautious when it comes to my cars. I dont like to do things to it that I think will cause me headaches in the future.
Thanks for the quick response Turbo6man
It might with your speedo :lol: At 6000rpm 1st gear doesn't quite make 70kph with the manual. Usually the rev limiter will not let you go over 5750rpm in first gear which is about 65kph.
The turbo is actually quite highly geared in first (for a heavy car) which is why the guys with mods to the engine are quickly finding the limitations of the clutch.
  • Member For: 22y 2m 24d
I think the car feels at its fastest when you do this!! I love it feels tops!!
  • What's happening?
  • Member For: 22y 2m 19d
Yep love putting back to 1st especially when going through the twisties :thumbsup:
that's because you can only handle 70k's top spead thru the twisties. :hrmm:
Game on! :banghead:
  • Here since the start...
  • Member For: 21y 9m 28d
Basically of you can in the auto it's fine. If your going to fast and you try to shift manually it won't let you until you get below a certain speed.
