blacktur8oute Member 139 Member For: 11y 2m 20d Gender: Male Posted 28/09/19 07:06 AM Share Posted 28/09/19 07:06 AM Hi all ive just had my ZF rebuilt and I’ve just fitted it back to the car When moving the selector lever from the transmission under the car the back wheels turn when I rotate them in all the positions P R N D and when the lever is in the DRIVE position it turns like it in neutral smoothly should it take a bit of forse when turning the back wheels in drive for them to turn is this normal will it adjust once it’s ready to be started, also even with the cable fitted to the transmission selector and I do the same from inside the car does the same thing I’m concerned should I be Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 11y 2m 20d Gender: Male Posted 28/09/19 08:21 AM Author Share Posted 28/09/19 08:21 AM I’ve just also tuned the engine from the harmonic balancer bolt and positioned the selector in all of the previous positions P R N D and the tail shaft is not turning long like in netutal but when I do the same and rotate the wheels the tail shaft turns Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 4m 28d Gender: Male Posted 29/09/19 07:39 AM Share Posted 29/09/19 07:39 AM just terrible Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 11y 2m 20d Gender: Male Posted 29/09/19 08:57 AM Author Share Posted 29/09/19 08:57 AM Could I of not installed the convertor properly? Checked to make sure and all was good and bolted up perfect to the flex plate and the block, could it be that there is only oil in the pan as car hasn’t been started yet to pump in the amount required Link to comment Share on other sites More sharing options...
