Slowxr6t Member 579 Member For: 6y 5m 2d Location: New zealand Posted 23/12/19 07:25 AM Author Share Posted 23/12/19 07:25 AM My arc welding doesn't look pretty but it's as strong as a tank and it's only on the thick walled steam pipe, the tig welding is good done by my engine builder in town, the mig welding done by neighbor. It's all heat wrapped now with titanium wrap so cant be seen. I got a professional cast welder to weld the short bit of 40mm steam pipe on to turbine housing, he cooked it up first in his oven and post heated it to cool slowly, worked out mint, no wastegate restrictions or problems. I made 10mm steel brackets and they are welded to dump and the factory 2 dump brackets bolt to them, I'm real pleased with it. Did 414rwkw at 18psi and pulled it back to 15psi 382rwkw to save driveline and pistons. Link to comment https://www.fordxr6turbo.com/forum/topic/95234-dump-pipe/page/2/#findComment-1690994 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m 4d Gender: Male Posted 23/12/19 09:15 AM Share Posted 23/12/19 09:15 AM Welp, it certainly won't rust out any time soon Link to comment https://www.fordxr6turbo.com/forum/topic/95234-dump-pipe/page/2/#findComment-1690998 Share on other sites More sharing options...
Slowxr6t Member 579 Member For: 6y 5m 2d Location: New zealand Posted 23/12/19 09:32 AM Author Share Posted 23/12/19 09:32 AM Does that have maximum street cred @FiftyOne ? Link to comment https://www.fordxr6turbo.com/forum/topic/95234-dump-pipe/page/2/#findComment-1690999 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m 4d Gender: Male Posted 23/12/19 10:47 AM Share Posted 23/12/19 10:47 AM I guess it should make the bitches moist Link to comment https://www.fordxr6turbo.com/forum/topic/95234-dump-pipe/page/2/#findComment-1691001 Share on other sites More sharing options...
