  • Dropping a turd
  • Member For: 17y 5m 24d
Just try google it will explain all. One is at the top of the engine other is at the bottom.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 10d
head studs hold the head to the engine block and main studs hold the main caps and subsequently the crank to the bottom of the engine.
  • Site Developer
no. just get head studs if you're going for bigger power... the main studs are only done when you do bottom-end work; e.g. when you build your engine.
