pieterv3812 Member 29 Member For: 7y 4m 5d Posted 23/09/19 08:43 AM Share Posted 23/09/19 08:43 AM I know it might be a stupid question. But can I run my na bf falcon on lpg and e85. Thanks for the answers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,054 Member For: 16y 8m 14d Gender: Male Location: Melbourne Posted 23/09/19 09:42 AM Share Posted 23/09/19 09:42 AM it'd be like running unleaded and lpg at the same time. you'd need two sets of fuel system etc... would be super expensive and you'd want to switch tunes when you switch fuel sources so you'll need two tunes etc. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 9m 28d Gender: Male Location: Frankston, 3199 Posted 23/09/19 10:09 AM Share Posted 23/09/19 10:09 AM Maybe an option with the pcmtec flex fuel Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 7m 15d Posted 24/09/19 03:30 AM Share Posted 24/09/19 03:30 AM It might be reasonably hard to do on a budget build system, for little to no gain. If your car is LPG allready, you could proberly get a FG turbo manifold (for the direct upwards TB) Fit a carby to it, with a smallish jet size, with a similar opening to the stock TB, but remove the throttle blades. run that to a secondarily e85 tank Fir the stock LPG throttle body on-top of that. block off the std injector ports. start it and see what happens. otherwise to do it properly you might want a new instake manfold with two sets of injectors, do e85 set and egas set. you will then proberly need a haltech for 12 injector control and it will cost alot for verry little reward. IDK if you could just fit a meth injection system and fit it with e85 instead of meth? Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 12d Gender: Male Location: SW Sydney Posted 24/09/19 07:10 AM Share Posted 24/09/19 07:10 AM 3 hours ago, BeerTurbo said: reasonably hard ................................for little to no gain. 3 hours ago, BeerTurbo said: it will cost a lot for very little reward. QFT Link to comment Share on other sites More sharing options...
pieterv3812 Member 29 Member For: 7y 4m 5d Posted 24/09/19 10:50 AM Author Share Posted 24/09/19 10:50 AM 7 hours ago, BeerTurbo said: It might be reasonably hard to do on a budget build system, for little to no gain. If your car is LPG allready, you could proberly get a FG turbo manifold (for the direct upwards TB) Fit a carby to it, with a smallish jet size, with a similar opening to the stock TB, but remove the throttle blades. run that to a secondarily e85 tank Fir the stock LPG throttle body on-top of that. block off the std injector ports. start it and see what happens. otherwise to do it properly you might want a new instake manfold with two sets of injectors, do e85 set and egas set. you will then proberly need a haltech for 12 injector control and it will cost alot for verry little reward. IDK if you could just fit a meth injection system and fit it with e85 instead of meth? It's already got lpg petrol dual fuel. Was just wondering if I could put e85 into the petrol tank with as ll the right gear to run e85 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 12d Gender: Male Location: SW Sydney Posted 24/09/19 06:35 PM Share Posted 24/09/19 06:35 PM It may be possible but will definitely be expensive and gains will likely be bugger all. Would be 10x better off selling the car and buying a T if it's performance you're after. I'm guessing you got the car around the same time you joined the forum? Link to comment Share on other sites More sharing options...
pieterv3812 Member 29 Member For: 7y 4m 5d Posted 24/09/19 10:15 PM Author Share Posted 24/09/19 10:15 PM I'm still on my P plates. So turbo is out of the question. However as soon as I get my full licence I'll be buying a t. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 10m 12d Gender: Male Location: SW Sydney Posted 25/09/19 12:33 AM Share Posted 25/09/19 12:33 AM In that case, save your money - you'll want it for mods to the T 2 Link to comment Share on other sites More sharing options...
