Hornblower Member 50 Member For: 22y 1m Location: Spit Junction NSW Posted 21/09/19 12:25 AM Share Posted 21/09/19 12:25 AM Morning, folks. I have an original auto BAXR6T (owned since new, in fact I joined this forum early 2003 when I bought it, just a handful of members then haha). Anyway, the thing is quite temperamental to start. She's not a daily driver, but once warmed up the issue doesn't appear. I'll come to the car after a week or two away, maybe as a little as a day or two away, turn the key and just get a click-clack relay (the fuel pump primes fine, battery power seems good). Sometimes the car will fire up fine on the next try, sometimes, it will just do the old click-clak several times then fire up fine (in between I try shifting the thing into neutral and try there, shift it back) etc. Once the car has fired up, and had a drive, and the engine is warm, this doesn't happen anymore. But let it cool down, sit overnight or for a few weeks, invariably I go through the same process again. It will always end firing up though, might take a minute or two, or straight away so I am never left stranded. 12 months ago a local mechanic suggested the ECU be removed and sent to Injectronics in VIC for refurbishing as a fix, but the problem still rears its head. The car has only about 150,000kms on the clock. Should I be looking now at other culprits such as solenoid, starter motor, maybe even security keys (I have both original ones)? Any advice greatly appreciated! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,274 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 21/09/19 01:07 AM Share Posted 21/09/19 01:07 AM Well, if you get the click-clack of the starter motor relay, then your circuit for the starting of the car is working correctly so that rules out keys/solenoid/wiring. The symptoms as you describe them just sound like an aging/dud battery. 1 Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 22y 1m Location: Spit Junction NSW Posted 21/09/19 02:02 AM Author Share Posted 21/09/19 02:02 AM Thanks for the reply k31th, I'll try a new battery in it and update the thread once its in Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,274 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 21/09/19 02:05 AM Share Posted 21/09/19 02:05 AM Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 11m 3d Posted 21/09/19 07:13 PM Share Posted 21/09/19 07:13 PM Try turning on the headlights & then try to start it, if they go really dull then it's your battery Link to comment Share on other sites More sharing options...
vegie New Member 8 Member For: 5y 7m 3d Posted 22/09/19 09:29 PM Share Posted 22/09/19 09:29 PM Sounds very 'battery related' to me, having had this myself. Do you have one of those small battery jump starters (always good to have one anyway). Before you start it (cold), connect the jump starter (charged) to the battery, then try and start. If it starts without the click-click, your battery needs replacing. Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 22y 1m Location: Spit Junction NSW Posted 11/10/19 07:54 AM Author Share Posted 11/10/19 07:54 AM Yep I do have one of those battery packs and I'm heading down to the falcon this weekend after 3 weeks away, so I will give that a go as you suggest. I'll let you know how it goes. Thanks for the tip. Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 22y 1m Location: Spit Junction NSW Posted 01/11/19 03:20 AM Author Share Posted 01/11/19 03:20 AM Update - I've now been back to the Falcon twice, both times I connected a fully-charged battery jump starter to the car battery before turning the ignition on. Both times I get the click-clack at least twice before the engine fires up properly. After a good run or so, the car restarts fine without any of the click-clack rubbish. So it doesn't appear to be battery-related. Any other tips on where to look for a solution? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,274 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 01/11/19 03:28 AM Share Posted 01/11/19 03:28 AM when you connected the jump started to the car battery, did you only have the positive on the positive terminal and the negative for the jumper on the engine block or chassis earth somewhere? Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 22y 1m Location: Spit Junction NSW Posted 01/11/19 07:19 AM Author Share Posted 01/11/19 07:19 AM I tried it both ways (the first time with the negative for the jumper on the chassis, and the second time with the negative for the jumper connected to the negative of the car battery). Same result each time. Link to comment Share on other sites More sharing options...
