  • Bronze Donating Members
  • Member For: 11y 10m 2d
Any tips on how to get a spanner on the oil feed line under the manifold at all? going in via the airbox local. isn't helping at this stage.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 23d
you need to cut a spanner to get it in there between the starter motor and the oil feed line.
  • Dropping a turd
  • Member For: 17y 6m 6d
24mm spanner through the manifold. 24mm long reach socket on the oil fitting .
I had another go.   If you remove the dip stick and the airbox, you can squeeze your hand in under the thermostat housing, assuming you've already untwitched it.   *May not work with all for setups or forearms*
