Off stock manifold or turbine housing for external wastegate location
  • Member For: 6y 6m 18d
@BeerTurbo I like the j pipe, but intake, outlet, oil and water lines would all need modifying in my case.
  • Dropping a turd
  • Member For: 17y 7m 26d
  On 17/09/2019 at 4:05 AM, Slowxr6t said:
What's wrong with stock engine mounts? What aftermarket ones are best?
Expand
Nothing.  Just hard to change . Best done with turbo off
  • Member For: 7y 1m 13d
Expand
allready had a braided oil feed - that works fine with highmount to.
cut the oil return pipe in the solid part and conected oilproof hose to it to extend the length.
overflow side water line works fine with a bit more hose, it has a small join std, just needs a bit more highmount.
I did bend the engine side water line to work, but it was a right *beep*. ended up replacing it with a different fitting and hose.
