BF Mk 2, not unopened anymore, not stock turbo anymore
  • Member For: 10y 3m 9d
  • Gender: Not Telling
What issues did you come across? Just the usual immediate post build stuff like leaks etc?
Edit: you said rollers, is he gonna do hub and roller while you're there?
Edited by Puffwagon
Surprised to see a block split at that power level but I guess they do, if yours did.
It's not a small task to fix that, look into options before you spend up big.
Fark sake, breaking at that power level is pretty bad, but at least it didn't catastrophically fail. It could have taken the rest of the rotating assy with it.
  • Member For: 5y 10m 8d
Yeah, apparently it was just bad cylinder wall thickness. It's unfortunate that two machine shops didn't pick it up.
But realistically, a small frame turbo setup will always be more vulnerable from cylinder pressure at lower rpm
Apparently cyl 5 is most common. Followed by cyl 1 & 6.
