Tom Tucker Donating Members 703 Member For: 5y 10m 6d Posted 06/12/22 09:49 PM Author Share Posted 06/12/22 09:49 PM Yep, for your FG, the 5 bar and loom is what you want. The resolution refers to the number of cells below 0 manifold pressure that are available to input values against everything from fuel trim, ignition timing etc. The 4 bar would hunt around the smaller number of tuning cells, and consequently drove like arse. The Omni 5 bar has changed everything from idle, transient throttle, engine smoothness, ignition timing stability, fuel economy. Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716134 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 5d Gender: Male Location: Adelaide Posted 07/12/22 12:45 AM Share Posted 07/12/22 12:45 AM Always happy to help you out Zane 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716136 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,342 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 07/12/22 01:23 AM Share Posted 07/12/22 01:23 AM On 06/12/2022 at 9:07 PM, hjtrbo said: I'm still not clear on the Tmap part. I presume it was boost and throttle transients where the old way suffered???? Regardless, to confirm, I take it the new way ford is the 4 bar boost sensor and 5 bar tmap kit like the following.... https://www.independentmotorsports.com.au/ford-fg-fgx-xr6-barra-5-bar-map-sensor-kit Expand Tom Tucker is using a Haltech so doesn't use the tmap switchover like the stock pcm with a PCMTec custom OS does. As such for a stock pcm you would only use the Omni 5 bar tmap and disable the tmap switchover if you wanted to use a single sensor. On 06/12/2022 at 9:49 PM, Tom Tucker said: The resolution refers to the number of cells below 0 manifold pressure that are available to input values against everything from fuel trim, ignition timing etc. The 4 bar would hunt around the smaller number of tuning cells, and consequently drove like arse. The Omni 5 bar has changed everything from idle, transient throttle, engine smoothness, ignition timing stability, fuel economy. Expand There is a little bit more resolution in the 5 bar tmap sensor and it is primarily right down the bottom, it measures -10psi vs -7psi for the 4 bar bosch tmap. It has a slightly more overall resolution as well. This is why it works better for the Haltech as it isn't a speed density based ecu and actually needs something that can measure down there. Ideally you would use a sensor that can measure down to -14.7psi as this covers the entire off boost section of the Haltech base maps. It isn't entirely necessary as decel vacuum will be more than idle vacuum so a single load cell column can do that job, as well as having dedicated decel parameters available. For now the 5 bar tmap has added 2 extra load cell columns (over a Bosch 4 bar tmap) and those 2 are the most commonly used around idle, decel and transient throttle and in particular a gearshift with a manual car. As far as the hunting issue goes there are other more likely reasons than resolution, but we're talking about a non issue now so there isn't much point discussing further. You could dial in most of this extra room in the table in your driveway with the rear of the car on jack stands. There's some info to help understand why things are things. Fwiw the Bosch 3 bar tmap/blue tmap is an even bigger pos than the Bosch 4 bar tmap. Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716138 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 322 Member For: 14y 3m 17d Posted 07/12/22 02:30 AM Share Posted 07/12/22 02:30 AM On 07/12/2022 at 1:23 AM, Puffwagon said: As such for a stock pcm you would only use the Omni 5 bar tmap and disable the tmap switchover if you wanted to use a single sensor. Expand Gold, thanks man 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716139 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 6d Posted 22/12/22 08:25 AM Author Share Posted 22/12/22 08:25 AM Got fuel economy down to 20L/100km, which is a vast improvement. Just completed a 400km road trip and it performed flawlessly. Took the old man for a spin on the low boost setting - bit of a fright for a guy who normally drives around at 20km/h under the speed limit. I'm really happy with my turbo choice for this car. The G35-900 makes a great manual street car. I've got usable boost at 2000rpm, and it's never far away from frying tyres whenever required. I know I still owe footage - maybe in the new year! 2 Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716414 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 322 Member For: 14y 3m 17d Posted 22/12/22 10:56 AM Share Posted 22/12/22 10:56 AM Lol 20L/100km. Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1716415 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 6d Posted 04/02/23 12:46 AM Author Share Posted 04/02/23 12:46 AM Not much to report on this bad boy. I've moved to Canberra, and have been pretty busy. Everything seems to be working as it's supposed to, and the tune gets better and better with every drive. Only thing I need is new tyres. Just have to work out the best semi slick option. ET Streets seem to be ridiculously expensive these days... Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1717102 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 1m 8d Gender: Male Location: Perth, WA Posted 06/02/23 02:59 AM Share Posted 06/02/23 02:59 AM Can try that new hero brand out? Raiden Hero I think they're called I've got AR-1's (nankang) and can't complain, but that is solely due to the fact I paid like $220 each. I'd be way more critical if I'd paid full retail on them I imagine. Even still, once they're warm, I'm getting all 400kw to the ground and it feels like a rocket. From a 2nd gear roll on the streets, tyres at 30-32 psi, I can leave traction control on and hardly see the light pop on the dash. Semi slicks are mad Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1717119 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 6d Posted 06/02/23 05:57 AM Author Share Posted 06/02/23 05:57 AM Yeah, A1R seem to be around $370 a tyre, which I'm not keen on. I think I might try Nitto NT01 Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1717123 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,342 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 06/02/23 06:18 AM Share Posted 06/02/23 06:18 AM Find someone who will get them for cost. I can get Nankang 255/40R17 AR1 for $170 per tyre. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95184-bf-mk-2-unopened-stock-turbo/page/22/#findComment-1717126 Share on other sites More sharing options...
