Tom Tucker Donating Members 675 Member For: 5y 7m 26d Posted 03/05/22 10:18 AM Author Share Posted 03/05/22 10:18 AM Breakfast laps at QR sucked. The track was wet, so I had zero traction. A few people crashed, so I'm lucky I avoided that. And nothing broke, which is handy. Just refining the tune. Having issues with it leaning out between gear changes, so I get hesitation. I'm assuming decel settings need to be investigated. Anyone do momentary ignition cut on gear changes, clutch switch activated? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,149 Member For: 10y 27d Gender: Male Location: South Australia Posted 03/05/22 11:13 AM Share Posted 03/05/22 11:13 AM 43 minutes ago, Tom Tucker said: I'm assuming decel settings need to be investigated. You been asking keef for boost control tips?! Decel is literally deceleration which is when you take your foot off the throttle and let it coast in gear. It has nothing to do with a gear shift. A lean hesitation after or while reapplying the throttle, is likely caused by not enough throttle pump enrichment or not a quick enough return to open loop fuel control. Farken people jump the gun and rather than sort the map out properly with no corrections, they try and tune with every farken correction enabled and as such end up with a car that runs like a bag of dicks. I've spent a long time just sitting in my driveway stabbing the throttle to get various cars acceleration enrichment sorted, after the base maps are done. It's a pita but it needs to be done for a complete tune. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 4d Posted 03/05/22 11:22 AM Share Posted 03/05/22 11:22 AM Wot box. Brendan around here did it. Had a cool video somewhere that I cant find. He was half mile racing or something at a airport. Don't ever think he found a clutch that could truly handle it. What bov you got?Alternatively nitrous seams to work for this fg Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 675 Member For: 5y 7m 26d Posted 04/05/22 08:10 AM Author Share Posted 04/05/22 08:10 AM I've got a T-56 Magnum. Clutch is a Mal Wood twin plate. Seems like a good combo. Sounds spot on Puff. Stabbing the throttle on idle results in coughing and spluttering with AFRs bouncing around from 10 to 22 Link to comment Share on other sites More sharing options...
joncitizen Member 91 Member For: 13y 5m 23d Posted 04/05/22 05:28 PM Share Posted 04/05/22 05:28 PM On 03/05/2022 at 8:18 PM, Tom Tucker said: Anyone do momentary ignition cut on gear changes, clutch switch activated? I want to do flat shifting in mine, but it's a long way off being tuned... Though that video above of NOS in between shifts sounds interesting. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 675 Member For: 5y 7m 26d Posted 28/06/22 05:04 AM Author Share Posted 28/06/22 05:04 AM Bit of an update. Had the tune revisited, and it turns out the changeover from NSP to NEXUS software screwed with correction tables. I also changed out the Dyno-Mite stage 1 cams for Atomic stage 3. Huge thanks to @JETURBO for hooking me up. The Atomics are actually more responsive, make more midrange by about 30kw, 100Nm more torque and also make more peak power, up to 613kw. That reminds me, this thread needs a bump up... 1 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,257 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 28/06/22 05:30 AM Share Posted 28/06/22 05:30 AM I thought the dynomite cams were the bee's knees haha guess that went out the window over time. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,257 Member For: 16y 10m 15d Gender: Male Location: Melbourne Posted 28/06/22 05:46 AM Share Posted 28/06/22 05:46 AM have moved to 600+ section 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,149 Member For: 10y 27d Gender: Male Location: South Australia Posted 28/06/22 07:10 AM Share Posted 28/06/22 07:10 AM Sounds like we need an up to date camshaft thread written by someone who has the data. How good would it be to test every camshaft back to back with the 2 most common upgraded turbo sizes, 35r and 42r?! Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 675 Member For: 5y 7m 26d Posted 28/06/22 08:55 AM Author Share Posted 28/06/22 08:55 AM Yeah true. So reviewing the data in more detail, there is up to 45kw difference in the low to mid range. Pretty amazing. The strange thing is the Dyno-Mite cams might actually be slightly faster in reality because of limited traction Link to comment Share on other sites More sharing options...
