Fuel pump to empty tank?
HOTXR6T
  • Member For: 14y 6m 18d
Yeah maybe I was lucky, I never read anywhere where it said to have 1/2 tank or less so I just parked it up and changed it out. When I could see the fuel level just below the opening I assumed it was close to full so it appears I was closer to 1/4 than full based on the shape of the tank.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m 1d
9 minutes ago, Head said:
Hmmm, maybe.
or your car was on an incline or something caused the fuel to stay in one location :idunno:
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 9m 8d
11 hours ago, arronm said:
To change must be less than half on gauge. 1/4 is better.
Bellenderitous is correct for once
anything past 2/3rds will piss fuel everywhere when undoing the retaining ring
halfway is a great guide without issues
Graeme if you’re not 100% certain I’ll happily do it for you ;)
  • Member For: 6y 7m 19d
Thanks for the offer Aaron, I think I will be ok doing it, I just was not sure how low the fuel had to be. If I have any trouble, I will give you a call. I appreciate all your advice and help buying the parts. I started working on the car today, I want to do all the work that has to be done on the ramps first, because I won' be able to drive it up the ramps latter, till its tuned. I'm thinking of doing the pump while I have it on the ramps, to keep the fuel at the  back.
  • Thanks 1
