k31th less WHY; more WOT Site Developer 29,455 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/06/19 07:25 AM Share Posted 23/06/19 07:25 AM that description is much better, thanks it sounds like a valve is sticking barely closed as you build the base amount of boost and then is opening when you get above 3psi. The only valve that could do this in the pathway is the BOV. The description reasonably clearly indicates the BOV opening while you've actually still got the throttle open (which is not how it should operate in normal conditions). Maybe the BOV is installed backwards or the BOV's actual internal valve seal is compromised and is opening when it should be shut. try blocking off the BOV connections to see if it builds boost properly (this isolates the problem to the BOV if it builds boost correctly). Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685628 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 11m 22d Posted 23/06/19 07:28 AM Share Posted 23/06/19 07:28 AM On 23/06/2019 at 6:50 AM, DoubleCee33 said: The blow off valve was completely removed and all of the lines connected to the above were either blocked off with screws or removed and blocked off completely. Expand On 23/06/2019 at 7:25 AM, k31th said: it sounds like a valve is sticking barely closed as you build the base amount of boost and then is opening when you get above 3psi. The only valve that could do this in the pathway is the BOV. The description reasonably clearly indicates the BOV opening while you've actually still got the throttle open (which is not how it should operate in normal conditions). Maybe the BOV is installed backwards or the BOV's actual internal valve seal is compromised and is opening when it should be shut. Expand I thought bov leak, but if its gone corectly then it wont be. if hes left the bov connected and blocked the vac going to the intake/bov that that would explain everything as the bov would be dumping at spring pressure override. upload a picture mate. Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685629 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,455 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/06/19 07:32 AM Share Posted 23/06/19 07:32 AM yeah... there's nothing that would really do what is described consistently if the BOV is actually removed... Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685630 Share on other sites More sharing options...
DoubleCee33 Member 27 Member For: 5y 10m 16d Posted 23/06/19 07:33 AM Author Share Posted 23/06/19 07:33 AM On 23/06/2019 at 7:28 AM, BeerTurbo said: I thought bov leak, but if its gone corectly then it wont be. if hes left the bov connected and blocked the vac going to the intake/bov that that would explain everything as the bov would be dumping at spring pressure override. upload a picture mate. Expand https://www.facebook.com/groups/366302366774097/2899080506829591/?comment_id=2899087910162184&reply_comment_id=2899106740160301¬if_id=1561167987099684¬if_t=group_comment_mention that's a post I made the other day regarding this issue, pictures are attached. Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685631 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,455 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/06/19 07:35 AM Share Posted 23/06/19 07:35 AM it's not a public group, so we can't see it... and I doubt that the fact that's a "closed" group would let you set the permissions to "public" on your post within it. Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685632 Share on other sites More sharing options...
DoubleCee33 Member 27 Member For: 5y 10m 16d Posted 23/06/19 07:42 AM Author Share Posted 23/06/19 07:42 AM Not sure how to upload photos then sorry mate, it says "insert image from URL" but my photos are on my phone/computer... Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685634 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,455 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/06/19 07:44 AM Share Posted 23/06/19 07:44 AM instructions for posting images are here -> https://www.fordxr6turbo.com/forum/topic/92470-how-to-put-images-in-your-post/ Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685636 Share on other sites More sharing options...
DoubleCee33 Member 27 Member For: 5y 10m 16d Posted 23/06/19 07:49 AM Author Share Posted 23/06/19 07:49 AM Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685637 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,455 Member For: 17y 21d Gender: Male Location: Melbourne Posted 23/06/19 07:59 AM Share Posted 23/06/19 07:59 AM it all looks connected well there, so the likely situation is that one of your plastic pipes has split partially and only holds 3psi before it presses itself open or a similar thing is happening with the stopper you've used to block off the BOV port. Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685641 Share on other sites More sharing options...
DoubleCee33 Member 27 Member For: 5y 10m 16d Posted 23/06/19 08:20 AM Author Share Posted 23/06/19 08:20 AM Regarding your suggestion of the plastic piping: that's exactly what Antz Performance said and they recommended I take the plastic piping that connects the turbo to the start of the intercooler piping completely off so that I could check for any cracks underneath, which I did and there were none. Re your plastic stopper suggestions: that's also what I initially thought but then I took the plastic stopper off and there were no holes or cracks or anything like that, so just to make 100% sure I reinforced it with that piece of hose that used to connect to the blow-off valve and put an extra tight clamp on to it and there was no improvement. It's definitely a strange situation, Antz themselves are backing the idea that it's a boost leak but they have absolutely no idea where because as you have probably guessed just about every box has been tipped. I'll be taking it to the mechanic tomorrow morning to see what he has to say but I don't know where we go from here... Link to comment https://www.fordxr6turbo.com/forum/topic/94935-boost-leak-after-installing-turbo-side-induction-why/page/2/#findComment-1685642 Share on other sites More sharing options...
