Aus123 Member 25 Member For: 5y 10m Posted 22/06/19 02:12 PM Share Posted 22/06/19 02:12 PM (edited) hi was installing a new AFR gauge. got under the car to replace the sensor and noticed oil leak at the back of the transmission. was going to take to to workshop to ask but there are close during the weekends and couldn't wait to find out why. its 6sp manual with 430 kw any clue how and what should be done about it. what process are involved in fixing the leak or if can do it on my own.] never touched a transmission before. don't have any clue. cheers Edited 22/06/19 02:16 PM by Aus123 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,273 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 22/06/19 02:28 PM Share Posted 22/06/19 02:28 PM It just looks like the tailshaft has been out of it and some fluid leaked around the coupling joint and then was inserted back in. Doesn't seem like a constant leak. Clean it up and see if the leak returns and if so, get a replacement coupler joint (yoke). Link to comment Share on other sites More sharing options...
Aus123 Member 25 Member For: 5y 10m Posted 22/06/19 02:39 PM Author Share Posted 22/06/19 02:39 PM forgot to mention, I just balanced my tail shaft like 1 week ago and noticed this in there, asked them they said its oil came out of tail shaft from removing it. 1 week later later and its still there. thought might be transmission. its reddish kind of oil. thanks Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,273 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 22/06/19 02:48 PM Share Posted 22/06/19 02:48 PM yes, the red coloured oil is definitely transmission fluid just clean it up and see if it returns straight away; that'll give you an idea on the severity of the leak, if there actually is one. 1 Link to comment Share on other sites More sharing options...
Aus123 Member 25 Member For: 5y 10m Posted 23/06/19 12:45 PM Author Share Posted 23/06/19 12:45 PM cleaned up as soon as I saw your reply, went back there this morning. the leak was there again do you mean driveshaft coupling https://www.autolinkparts.com.au/kelpro-kdc1000-tail-shaft-rubber-coupling-suit-for like this one thanks for y help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,273 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 23/06/19 12:47 PM Share Posted 23/06/19 12:47 PM well, you'll need one of those (that suits your tailshaft) with a new yoke... depending on where the leak is actually coming from. I'd take it to a transmission place for them to at least diagnose where the leak might be coming from before you make any purchases. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 2d Gender: Male Location: Perth Posted 23/06/19 02:47 PM Share Posted 23/06/19 02:47 PM Degrease it and go for a drive. Then check again. Oil will spray around with the rotation of the yoke. Link to comment Share on other sites More sharing options...
