Transmission Oil leak
Aus123
  • Member For: 5y 7m 1d
hi
was installing a new AFR gauge. got under the car to replace the sensor and noticed oil leak at the back of the transmission.
was going to take to to workshop to ask but there are close during the weekends and couldn't wait to find out why.
its 6sp manual with 430 kw
 any clue how and what should be done about it.
what process are involved in fixing the leak or if can do it on my own.]
never touched a transmission before. don't have any clue.
cheers
Edited by Aus123
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 7m 23d
It just looks like the tailshaft has been out of it and some fluid leaked around the coupling joint and then was inserted back in. Doesn't seem like a constant leak. Clean it up and see if the leak returns and if so, get a replacement coupler joint (yoke).
forgot to mention, I just balanced my tail shaft like 1 week ago and noticed this in there, asked them they said its  oil came out of tail shaft from removing it.
1 week later later and its still there. thought might be transmission. its reddish kind of oil.
thanks
  • Site Developer
yes, the red coloured oil is definitely transmission fluid
just clean it up and see if it returns straight away; that'll give you an idea on the severity of the leak, if there actually is one.
  • Site Developer
well, you'll need one of those (that suits your tailshaft) with a new yoke... depending on where the leak is actually coming from. I'd take it to a transmission place for them to at least diagnose where the leak might be coming from before you make any purchases.
  • Dropping a turd
  • Member For: 17y 1m 6d
Degrease it and go for a drive.  Then check again.  Oil will spray around with the rotation of the yoke.
