  • 3 months later...
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 13d
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 17d
Sorry but they don’t work matty, there’s a reason ford didn’t use them after 2003
  • Member For: 11y 1m 13d
The 2012 FG-T uses a quality silicone sealant only on the front timing cover in the factory Assembly process.
But unfortunately the robot machine feed tube clogged during assembly ( went unnoticed ) on many engine assemblies.
Mine was one, causing a very slow oil seep/leak and was fixed by Ford after a lot of pushing for me. Is all good now.
German or Japanese  sealants make the best brands of Silicon sealants.
  • 2 weeks later...
  • MattyP
  • Cruise Control
I always had a weep at the front of the sump unfortunately,
Can the sump come off without taking out the crossmember?
I would think that to do a good job , it would have to come off. Mine was done at Ford and the full job took 2 full days.
A question for the more experienced guys who strip down these engines.
" I too do not tolerate oil leaks as it takes the 'shine' off a good car."
