Aus123 Member 25 Member For: 5y 7m 26d Posted 10/06/19 03:08 PM Share Posted 10/06/19 03:08 PM HI I have been looking the internet for sump (pan gasket) for my fg turbo 2010 but couldn't find any for fg models. I 've seen for ba-t and etc but not for fg. like this one that has no fg mentioned =====> https://www.autolinkparts.com.au/oil-pan-sump-gasket-suit-ford-falcon-ba-bf-fpv-6cy~53636 I am planning to put a my old oil pump into my engine from my old engine. the process don't look hard to me for now but I take any advice. about the gasket. I looked the internet couldn't find any for the for fg models so I decided to use silicon Gasket like this https://www.supercheapauto.com.au/p/permatex-permatex-high-temp-rtv-silicone-gasket-maker---red-311g/114971.html?cgid=SCA01081001. I assume it does same thing as a gasket rubber. would it be already to use that Silicone Gasket . about the front panel gasket. where the drive belts is. https://www.golebysparts.com.au/products/ba-bf-fg-ford-falcon-barra-timing-gasket-and-seal-set-tcs48 . is this the right one to use. thanks Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 6m 26d Gender: Male Location: Adelaide Posted 11/06/19 06:58 AM Share Posted 11/06/19 06:58 AM None of the gaskets work well enough imho and a properly prepared timing chain cover and sump with correct silicone liquid sealant works best 2 Link to comment Share on other sites More sharing options...
Aus123 Member 25 Member For: 5y 7m 26d Posted 12/06/19 01:17 PM Author Share Posted 12/06/19 01:17 PM you mean the liquid silicone off the shelf from supercheap auto. the good brand. use it on top of with gasket ? thanks mate Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 7m 26d Gender: Male Location: Western Sydney Posted 12/06/19 08:29 PM Share Posted 12/06/19 08:29 PM No gasket.Just sealant.Give it a decent bit of time to cure before driving it. The last thing you want is for it to leak after all that labour. 1 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 3m 26d Posted 12/06/19 11:22 PM Share Posted 12/06/19 11:22 PM So this is exactly like the Coyote's I work on daily, compared to my Barra I've worked on once in the last month. Clean and removed all old silicon from the factory seals (oil pan and timing cover gaskets) reuse and add new silicon to the area's where 1.The oil pan, block, and bottom of timing cover meet. 2.The head meets the block, and timing cover. 3.The valve cover meets the head, and front timing cover. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 6m 26d Gender: Male Location: Adelaide Posted 12/06/19 11:47 PM Share Posted 12/06/19 11:47 PM Yup, exactly Preparation of the surfaces is the key here though and I file finish by hand to get the desired touch finish 1 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 3m 26d Posted 13/06/19 12:16 AM Share Posted 13/06/19 12:16 AM Yes, buy yourself a plastic razor blade, it'll be your new best friend while prepping those surfaces. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 3m 4d Gender: Male Posted 13/06/19 12:21 AM Share Posted 13/06/19 12:21 AM 3bond 1211 or loctite 5910 works very well for this job. Don’t forget to put it on the oil pan front section too before you install the timing cover otherwise it will leak oil and gather around the half moon gasket near the balancer. surfaces must be super clean, both those sealants will work well. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 6m 26d Gender: Male Location: Adelaide Posted 13/06/19 12:27 AM Share Posted 13/06/19 12:27 AM 8 minutes ago, SelectivePC said: Yes, buy yourself a plastic razor blade, it'll be your new best friend while prepping those surfaces. Have a unique easy way of getting the old silicone off that’s never the issue it’s all about getting the right amount of sealant on,where you put it on and the surface finish before it goes on Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 3m 26d Posted 13/06/19 02:48 PM Share Posted 13/06/19 02:48 PM Oh yeah, no need to go crazy with it. Link to comment Share on other sites More sharing options...
