boost gauge install vacuum problems
Killerxr6turbo
  • Member For: 6y 4m 5d
hi I finally installing my boost gauge I have used the bluetooth power supply under dash for power and illumination I have the Autotechnica gauges the volts gauge works fine the boost gauge works just not reading vacuum its showing the highest reading all the time which is 45.
the engine is nizpro stage two with intake plenium I got hose hooked up to this spot on engine but there is no reading should I be hooking it up to another spot as its not reading from this spot
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 11d
yes, that nipple is the correct place to get a vacuum/boost source... is the gauge electronic or mechanical?
  • Trust me bro...tbh ;) 8===}
  • Member For: 9y 11m 23d
Double check your ground and power supply. Check a fuse if needed. Check the electric plug is properly seated in the back of the gauge and make sure the hose is intact and not blocked.
All obvious stuff but that's where you need to look.
Edited by Puffwagon
