FAT570 New Member 13 Member For: 13y 5m Posted 06/05/19 03:28 AM Share Posted 06/05/19 03:28 AM Hey Guys just need some help on which fuel pump to use. Car is a fg xr6 turbo sedan will run about 300-320rwkw was thinking getting the below https://www.ebay.com.au/itm/FALCON-FG-FGX-XR6-TURBO-XR8-FPV-WALBRO-TIA485-2-E85-460LPH-FUEL-PUMP-ASSEMBLY/292221813419?hash=item4409c702ab:g:ZLEAAOSwT-lZmldk&frcectupt=true any help would be appreciated. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 28d Gender: Male Location: Melbourne Posted 06/05/19 03:30 AM Share Posted 06/05/19 03:30 AM for 320rwkw, a GSS340 is plenty for an in-pod pickup pump and provides the pickup abilities for surge-tank setups if you go that way for more power in the future. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1682992 Share on other sites More sharing options...
FAT570 New Member 13 Member For: 13y 5m Posted 06/05/19 03:44 AM Author Share Posted 06/05/19 03:44 AM Thanks K31th Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1682993 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 15d Gender: Male Location: Canberra ACT Posted 06/05/19 04:06 AM Share Posted 06/05/19 04:06 AM Plus if you went the 460, you'd have to modify your return and possibly need a new regulator to keep your fuel pressure correct.My FG is about that power and I've got the pump Keith mentioned above. You could probably get away with a factory FG pump, but I'd rather know the pump could easily keep up. Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1682995 Share on other sites More sharing options...
FAT570 New Member 13 Member For: 13y 5m Posted 06/05/19 04:16 AM Author Share Posted 06/05/19 04:16 AM yeah we went to dyno it but had some issues so tuner suggested could be the fuel pump and I guess it's better to be safe then sorry Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1682996 Share on other sites More sharing options...
Slowxr6t Member 589 Member For: 6y 7m 4d Location: New zealand Posted 04/06/19 08:22 AM Share Posted 04/06/19 08:22 AM Have any of you guys used a kpm motorsports 700hp fuel module, anti surge pump? I see it uses a 540lph walbro, that's pretty huge. Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1684555 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 7y 1m 29d Posted 04/06/19 08:37 AM Share Posted 04/06/19 08:37 AM If you buy the 460 you will need to switch the fuel regulator, GFB make a bolt in unit that's will solve the problem. the issue is the stock reg has quiet a small return hole, so when you get a big boy fuel pump the fuel cant actually return to the tank fast enough and you end up over pressurizing your fuel feed. You will also need to upgrade the power cables to the cradle, as that pump will eat around 22amps and the stock wiring is proberly only good for 14a. 320 Kw you will proberly only need around 200 LPH of fuel flow, have you considered just using a 255lph drop in fuel pump? this would mean you dont have to change the fuel pressure regulator, nor the wiring. if you plan to use the car in a way that the fuel will slosh around, like hard cornering accelerating for bulk periods of time, then you might actually be better with a surge tank and pump setup. for that power level you could use your stock in-tank pump as a lift pump and fit whatever pump you want tot he surge tank to guarantee its allways got fuel flow. usually the surge tank will be closer to the engine bay to, so running the upgraded fuel pump wiring is somewhat easier. Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1684558 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 8m 29d Gender: Male Location: Mildura Posted 04/06/19 09:46 AM Share Posted 04/06/19 09:46 AM If you don't upgrade your wiring and plug, you'll end up with this..You should do it like this... Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1684560 Share on other sites More sharing options...
Slowxr6t Member 589 Member For: 6y 7m 4d Location: New zealand Posted 05/06/19 04:21 AM Share Posted 05/06/19 04:21 AM How many amps can the 2015 fgx xr6 turbo fuel pump wiring handle? Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1684625 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 7d Gender: Male Location: Adelaide Posted 05/06/19 08:48 AM Share Posted 05/06/19 08:48 AM What size is the fuse usually a dead giveaway....... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94803-which-fuel-pump/#findComment-1684648 Share on other sites More sharing options...
