FiftyOne Bronze Donating Members 1,145 Member For: 11y 9m 29d Gender: Male Posted 30/04/19 01:20 AM Share Posted 30/04/19 01:20 AM On 29/04/2019 at 12:32 PM, El Andrew said: 20L delivered to your door for about $150. Bargain! Expand I <3 Bananas that's cheap Link to comment https://www.fordxr6turbo.com/forum/topic/94752-transmission-problem-help/page/2/#findComment-1682639 Share on other sites More sharing options...
DrG6E New Member 11 Member For: 6y 8m 21d Location: Adelaide Posted 01/05/19 04:52 AM Share Posted 01/05/19 04:52 AM (edited) G'day G6eTurboDaily, Have seen something similar on my mates F6, his dashboard would light up as well when under load and changing gears, the gearbox was saying something like 'over maximum torque limits'. From memory it was all to do with the time between clutches letting go and grabbing while changing gears. He did however managed to get his gearbox re-programmed locally (here in Adelaide) for faster shift times between gears, it seemed to solve the issue. Dunno if this helps but its just my 2 cents... maybe try the service first... Edited 01/05/19 04:52 AM by DrG6E Link to comment https://www.fordxr6turbo.com/forum/topic/94752-transmission-problem-help/page/2/#findComment-1682717 Share on other sites More sharing options...
LadsterXR6t New Member 1 Member For: 4y 6m 21d Posted 09/10/20 11:44 AM Share Posted 09/10/20 11:44 AM Hi G6eTurboDaily, did you end up finding out what was going on? I've had the same issue come up. I was on the highway and went to overtake and it dropped to 3rd gear and had "Transmission Fault" show up on the dash. Once I turned it off, it went away but came on again a couple hours later once I hit 15PSI in 5th gear. I had the gearbox serviced about 3 months ago/5000kms ago, so I don't think it would be that. Just wondering if you found the issue. I'm thinking maybe a torque converter issue? Link to comment https://www.fordxr6turbo.com/forum/topic/94752-transmission-problem-help/page/2/#findComment-1699641 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 09/10/20 12:06 PM Share Posted 09/10/20 12:06 PM it's not a good idea to load up any gearbox in a ratio above 1:1 (e.g. anything above 4th in a ZF in your example)... always load it up in an appropriate gear and tune it for the shifts if you need to get up the higher speeds that the loaded gear can't cope with. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/94752-transmission-problem-help/page/2/#findComment-1699642 Share on other sites More sharing options...
purxr6t Member 37 Member For: 4y 11m 25d Posted 20/02/24 09:22 AM Share Posted 20/02/24 09:22 AM Recently purchased a 700+ Rwkw G6E Turbo that is also saying gearbox fault if put in "D" after half an hour or so. It doesn't seem to do it if driving in tiptronic, Although it usually does not seem to go to 6th in tiptronic without pushing shifter over into D. The ZF tune seems a bit rough. At around 40Kmh for example it bucks around into what seems like covertor lock up, Or shifting up and down gears, This is fixed by manually shifting, Down a gear to stop it hunting. It has a Haltech Plug in ECU if that helps. Would like a decent ZF Tune in there, As in "D" it barely drops a gear on the freeway. Supposedly the ZF is built with the bigger Ford Input shaft, And rated at 1000Hp. So can anyone do a decent ZF Tune, that can just be put into "D" for Drag Mode and drive well at that power level? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/94752-transmission-problem-help/page/2/#findComment-1722167 Share on other sites More sharing options...
