G6eTurboDaily New Member 3 Member For: 5y 7m 5d Posted 19/04/19 02:23 AM Share Posted 19/04/19 02:23 AM Hi everyone, I currently own a G6eTurbo 2010 model with approximately 100,000 kms. I have done nothing to the car besides a rear muffler delete, besides this it is stock as a rock. The other week I was driving on an expressway travelling at about 100 kmh and then accelerated, not an overly hard acceleration but was overtaking someone so a reasonable push. As I put the power in the car lost power and flashed “Transmission fault” on the display. It put me into limp mode (3rd gear). I pulled over turned the car off and turned it back on and it appeared fine let me drive normally. I took the car into a mechanic and explained my problem but they said they couldn’t find any codes and they test drove the car which appeared fine to them. Since this I have tested the issue myself and found once the car hits operating temperature if I apply any hard acceleration after about 100 kmh the car immediately faults, limp mode, turn it off back on and it runs fine. I borrowed a reader and found the following code myself: DTC - P0735 - Transmission gear #5 incorrect ratio. DTC status: Continuous memory DTC. Has anyone had this issue or know what is going on with my car! I don’t want to keep mechanic shopping and being charged silly amounts to be told its fine. Any help is greatly appreciated. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 4m 23d Gender: Male Posted 19/04/19 02:45 AM Share Posted 19/04/19 02:45 AM Hi mate. Certainly sounds odd? going to ask a fairly basic question here, what sort of rims & tyres are you running? Link to comment Share on other sites More sharing options...
G6eTurboDaily New Member 3 Member For: 5y 7m 5d Posted 19/04/19 02:51 AM Author Share Posted 19/04/19 02:51 AM Hi mate, Simmons FR1,s 20” front and back. Fronts are 8.5 wide and rears are 10 wide. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,991 Member For: 16y 7m 14d Gender: Male Location: Melbourne Posted 19/04/19 02:53 AM Share Posted 19/04/19 02:53 AM I'd say that the gearbox just needs to be serviced. Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 10m 27d Gender: Not Telling Posted 19/04/19 03:02 AM Share Posted 19/04/19 03:02 AM have your ignition coils been changed before? Caused some weird ass transmission sh1t for me, but not that specific fault code. it's at the kms where you want to service your box as keith said above. when servicing it should become clear if the box is torched. Link to comment Share on other sites More sharing options...
G6eTurboDaily New Member 3 Member For: 5y 7m 5d Posted 19/04/19 03:25 AM Author Share Posted 19/04/19 03:25 AM I see. Ignition coils haven’t been changed at all. I’ll look into a trans service anyone know the rough cost I’d be expecting and if the gearbox is “sealed”? Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 4m 23d Gender: Male Posted 19/04/19 06:16 AM Share Posted 19/04/19 06:16 AM 2 hours ago, G6eTurboDaily said: I’ll look into a trans service anyone know the rough cost There's a few good write up's on the site about it if you're inclined to do it yourself. If you take it to the pro's you probably looking at anything beyond $1,000 from memory its ~300 for the kit plus 70ish per liter for genuine ZF fluid of which you need about 14 liters for a full fill and labour on that. If you use dextron6 ZF compatible fluid you'll save a fair bit on the oil. The reason I ask about the wheels, there was something I remember with the Simmons I was going to get. Guy at the shop had said it could trigger ABS faults for some cars based on a different rolling diameter because of the sidewall ratio. I'm not saying that's the cause here, but maybe a bit of slippage in the box plus the wheels could be doing it? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 11m 25d Gender: Male Location: WA, Perth Posted 29/04/19 04:31 AM Share Posted 29/04/19 04:31 AM http://fordforums.com.au/dtc/dtc.php Go check your code up on this site. Fluid contamination within the transmission. Incorrect torque converter fitted. Mechanical defects with clutch packs. or Incorrect calibrations PCM/TCM. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 6m 15d Posted 29/04/19 08:15 AM Share Posted 29/04/19 08:15 AM On 19/04/2019 at 11:25 AM, G6eTurboDaily said: I see. Ignition coils haven’t been changed at all. I’ll look into a trans service anyone know the rough cost I’d be expecting and if the gearbox is “sealed”? Gearbox is not actually fully sealed they just do not have a level indicator for general users to check, they do have fill points on the side of the gearbox that are technically used to check the oil level. I recently serviced my ZF, Metal replacement pan and filter, from eBay $185. 20l of gulf western oil, was about $200... you can order it online from SCA but im in WA and they could not guarantee a reasonable shipping time (shipping was from over east, via road). I ended up going to repco and getting it same price same day. I also bought a transmission cooler to replace the factor w/o cooler, that was $310 service is made easier if you have the OBD2 adapter and can load up the transmission temp, as you need to fill it twice (once cold and once when it between 40-60deg-from memory) I think I ended up using about 18l of oil as I drained oil, added oil and drained oil a couple of times to try and clean out all the old oil. I believe the full dry refill is about 10l and part refil is about 4/5l (aka just sump) there is a thread on here somewhere with the ZF service guide, if you going to diy read it twice before starting, make sure you know what your up against. I cant tell you how much a mechanic would-charge to do the above. another point of mention here is that I bought the cheapest oil I could find with a ZF raiting, certain places may like to use the genuine stuff that is about $50 per L. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,035 Member For: 9y 7m 2d Gender: Male Location: Canberra ACT Posted 29/04/19 12:32 PM Share Posted 29/04/19 12:32 PM If you ring Gulf Western direct, they will supply 20L delivered to your door for about $150. Bargain!After doing that for the trans oil, I get all my oil direct from them now. 1 Link to comment Share on other sites More sharing options...
