  • Member For: 6y 11m 24d
is this part of the fuel tank setup?
I was under the impression you needed to drill out the return hole in the fuel pressure regulator itself, or purchase the bolt in GFB one when installing high flow pumps.
  • 4 years later...
  • Member For: 5y 3m 13d
  On 15/04/2019 at 5:45 AM, My_XR6_Turbo said:
Hi guys, I'm installing a walbro 460 intank pump and I know I need to drill the return line out to 4.5mm. Is this the right one? Can anyone explain what the center one is for as it's blocked? Thanks,
Expand
The centre 1 is used to hold it into the bottom of the pot, ( the locking pin ), I drilled mine out to 4mm, certainly quietened down the pump audibly, AFR at idle settled from low 12s to stoich, so it made a difference, though as suggested by BEERTURBO, just buy the GFB drop in reg
