How to remove zf 6 speed
Joel0201
  • Member For: 5y 10m 3d
Hey guys I have a bf turbo with a zf
I am swapping over the box as it’s faulty
I know the basics like remove starter undoing of converter ect
I was wondering if there is a how to for removal/install just for a bit of help/guildline if there’s not I will take pictures along the way when I do mine.
thanks
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 19d
Removing the starter motor and undoing coverter bolts from the starter motor hole is the hardest part, the rest is easy typical bell housing bolts and rear trans mount bolts from the sub floor, remove shifter link and heat exchanger then tailshaft out and away she goes mate ;)
Edited by JETURBO
  • Trust me bro...
  • Member For: 9y 11m 20d
Removing an auto box has been the same for the past 70+ years. The only extra bit is the wiring loom.
Here's a starter removal tip; use some creative visualisation and socket extensions to reach the top fastener.
  • 3 months later...
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 9d
jack up both ends of the car and there's room... can't imagine there'd be enough room on just ramps, but it could slide out the front once it's lowered, I guess.
It’s a tall box mate and ramps only might not cut it, this has been an issue with other cars when I was much younger and not having a hoist to use
maybe some big HD tall ramps will do it
