XR6T 520RWKW Member 40 Member For: 6y 3m 27d Posted 06/04/19 04:40 AM Share Posted 06/04/19 04:40 AM (edited) hi guys just wondering what bar (kg cm2, or PSI) is your FPR. it can be for e85 or 98. I can't turn mine down. can increase it but can't decrease it. currently setting on 5 KG but don't go any lower than that. Edited 06/04/19 04:46 AM by k31th fixed pic Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/ Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 21d Gender: Male Location: Western Sydney Posted 06/04/19 04:45 AM Share Posted 06/04/19 04:45 AM 4 bar58 psiGet a frp1200Or take it to a workshopPay them to do it instead of you not having a clue.And then stop starting useless farking threads. 3 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680869 Share on other sites More sharing options...
XR6T 520RWKW Member 40 Member For: 6y 3m 27d Posted 06/04/19 06:05 AM Author Share Posted 06/04/19 06:05 AM This is what forum is for Learning new things. I m pretty new to turbo site, 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680870 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 9m 9d Gender: Female Location: SA Posted 06/04/19 06:11 AM Share Posted 06/04/19 06:11 AM You’re pretty new to cars in general it seems. Take it to a tune shop ... or not... watching the threads progress to “I blew up turbo what to do next” would be great. 1 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680871 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 2m 26d Posted 06/04/19 07:50 AM Share Posted 06/04/19 07:50 AM There's a restriction in the fuel return at the bottom of the pump module that has to be enlarged 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680872 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 21d Gender: Male Location: Western Sydney Posted 06/04/19 08:44 AM Share Posted 06/04/19 08:44 AM 20mm hole should do it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680873 Share on other sites More sharing options...
Head Member 74 Member For: 14y 10m 1d Posted 06/04/19 10:07 PM Share Posted 06/04/19 10:07 PM On 06/04/2019 at 7:50 AM, 4321 said: There's a restriction in the fuel return at the bottom of the pump module that has to be enlarged He doesn’t state what pump he is using, he’ll only need to mod the pump return if he is using a pump greater than a Walbro 255.Plus you guys are a bit harsh. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1680902 Share on other sites More sharing options...
XR6T 520RWKW Member 40 Member For: 6y 3m 27d Posted 09/04/19 02:35 PM Author Share Posted 09/04/19 02:35 PM Wondering what psi is enough for e85. Car was tuned previously just making sure things r good. Assuming 76 ish psi for 520 kw. Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1681121 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,565 Member For: 17y 2m 12d Gender: Male Location: Melbourne Posted 09/04/19 02:37 PM Share Posted 09/04/19 02:37 PM it'll be 58psi plus whatever boost you're pushing... so it's irrelevant once you've setup the fuel system correctly. Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1681122 Share on other sites More sharing options...
XR6T 520RWKW Member 40 Member For: 6y 3m 27d Posted 16/04/19 03:53 AM Author Share Posted 16/04/19 03:53 AM (edited) I have plazmaman Surge tank 1000 hp already installed connected to my turbo smart 800 fpr. I re-tuned my car coming off e85 to 98. and the tuner who tuned it was providing only tuning service and no mechanical service as it was only home service. my fpr gauge is showing 72 psi when I bought and still is at 72 . after doing my research I found out it should be at 4 bar plus the boost when turbo spool up I was trying to bring down the psi on my fpr but it don't work. the lowest it goes is 70 psi. I was told in the forum, to enlarge the return line by 20 mm but my fpr only has 1 line connected to the tank, second line for the injectors rails and 3 line for manifold ( I guess it act as sensor to tell fp to increase the fp when there is more boost). does any1 have this plazmaman fuel tank or do I have to disable one of the pumps . https://plazmaman.com/product/ford-falcon-fg-fuel-system-dual-pump-1300hp/ http://www.turbosmartdirect.com/Product-Categories/Fuel-Pressure-Regulators/FPR800-2017-Black.html# plz guys if you want to help me help other wise stop telling me to back off. Edited 16/04/19 03:57 AM by XR6T 520RWKW Link to comment https://www.fordxr6turbo.com/forum/topic/94710-turbosmart-fuel-regulator-800/#findComment-1681787 Share on other sites More sharing options...
