Natho724 New Member 18 Member For: 6y 6d Posted 23/02/19 01:08 PM Share Posted 23/02/19 01:08 PM Need help just bought a xr6t and when hitting boost around 4000rpm it cuts out and shutters and won't let you boost. But if I disconnect the pipe from intake side of cross over to bov I can rev it oit and boost has brand new plugs and packs genuine Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 11m 2d Posted 23/02/19 09:19 PM Share Posted 23/02/19 09:19 PM put a boost guage on & see what its boosting to.My guess is overboosting because of dud actuator. Good a place as any to start diagnosing Link to comment Share on other sites More sharing options...
Natho724 New Member 18 Member For: 6y 6d Posted 24/02/19 11:36 AM Author Share Posted 24/02/19 11:36 AM I hooked up a boost gauge it hitting 14 psi with the hose connected. And 7 with it not connected actuator seem to be working alright I liked it up and blew air in it and could hear it moving Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,269 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 24/02/19 11:39 AM Share Posted 24/02/19 11:39 AM well, then is it supposed to be tuned for 14psi? or is it stock? if it's stock, then it's making too much boost. Link to comment Share on other sites More sharing options...
Natho724 New Member 18 Member For: 6y 6d Posted 24/02/19 11:47 AM Author Share Posted 24/02/19 11:47 AM No it only stock so it's definatly over boosting Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,269 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 24/02/19 11:48 AM Share Posted 24/02/19 11:48 AM ok, so your wastegate flapper or arm or diaphragm is not acting as it should, or there is actually a tune in the vehicle. Link to comment Share on other sites More sharing options...
Natho724 New Member 18 Member For: 6y 6d Posted 24/02/19 12:02 PM Author Share Posted 24/02/19 12:02 PM Is there a way to test the Waste gate or do I have to remove the turbo and how to do tell if there is a tune I thought they hade to have a sct tuner with them or is there other ways to tune these forgive my ignorance first barra turbo Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,269 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 24/02/19 12:10 PM Share Posted 24/02/19 12:10 PM Take off the rear heat shield and the dump pipe and have a look at the movement of the actuator and flapper... and if you can connect a compressor to the actuator to see if it correctly actuates and the flapper opens fully when at the right pressure (the actual stock number changes depending on what actual model you've purchased). Nah, they don't have to be tuned via sct... they can be tuned via hptuners and pcmtec, too. If you can prove via a compressor that it's opening at hte correct pressure, then it's probably got a tune in it. Take it to ford and get them to put a stock tune back in it, if your car has all stock parts Link to comment Share on other sites More sharing options...
Natho724 New Member 18 Member For: 6y 6d Posted 24/02/19 12:25 PM Author Share Posted 24/02/19 12:25 PM Awsome thankyou ill give that a go tommorow the only thing after market I can notice is a fpv cooler and he said it was all stock it hade a 2half inch cat back but I put the stock back on Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,269 Member For: 16y 10m 19d Gender: Male Location: Melbourne Posted 24/02/19 12:30 PM Share Posted 24/02/19 12:30 PM the stock exhaust is twin 2.25" cat-back, so weird that it had a 2.5" cat-back at all, unless it was just for the mufflers being less restrictive... but yeah, all good, good luck with it all Link to comment Share on other sites More sharing options...
