  • ...JD TUNING ADELAIDE...
  • Member For: 17y 17d
Apples not be apples here boys
need to read all of the information on all of the pages
have a look at his turbo and what’s been done to it on a 0.5 housing
efficiency ———> window
  • Bronze Donating Members
  • Member For: 8y 10m 2d
66mm would make more power and certainly a lot more on 28psi. something isnt working as it should, either blockage or flow issues or the turbo isnt what was advised and isnt working effectively or efficiently
  • Member For: 10y 4m 18d
  • Gender: Not Telling
This is in the first post.
  On 21/02/2019 at 10:09 AM, F6 fitzi said:
Race equipped stage 3 turbo, 68mm billet core.
Expand
Heck knows why the dyno sheet looks like that. There is a spelling mistake in there for the correction factor so maybe another keystroke was incorrect and it changed something else???
 @F6 fitzi call dmp and ask them.
  On 29/03/2019 at 2:44 AM, arronm said:
Where does it say 0.5 housing
Expand
All the gold bars have blinded you over the years 🤩
a 68mm wheel in a 0.5 cover doesn’t reak of a good combo imho and clearly the boost pressure isn’t delivering Ltrs/min as one would assume on a 68mm
Dion knows a thing or two about tuning and wouldn’t just press on if something was wrong and clearly knows what a blocked exhaust looks and feels like on the Dyno
I strongly believe this is just the best this combo has in it and the actual fact is the combo is wrong imho
  • Member For: 9y 9m 13d
Wow very efficient, 475 @ 18psi. Whats the Torque on that?@ arronm.
Dion didn't like the exhaust flow turning 90° out the external gate. Could be a factor.
Restrictive cooler maybe.
  • Dropping a turd
  • Member For: 17y 7m 21d
Torque, dont know. 479rwkw   18psi tapering to 16psi at the top end
It ran out of pump as you can see. Simon backed off a bit and ended up with 472rwkw.
  • Dropping a turd
This hub dyno reads within 5rwkw of the mainline chassis dyno it replaced. It was back to back tested when installed.
