  • Member For: 21y 10m 19d
Hi guys.
I have been living with low speed (I.e. driving slowly in a car park) driveline shunt, but I want to try sort it out if at all possible.
Reading on the forums it seems that Ford claims this to be normal etc. however, I would like a way to eradicate as much of the low speed shunt as possible.
I had a new Eaton TruTrac diff put in at G&J Diffs Dandenong hoping this would fix the issue, at the same time the guys also checked the diff bushes - all was apparently OK with the bushes.
Whilst the car was on the hoist the guy was moving one of the rear wheels backward/forwards, and it moved quite a bit so there is some slack somewhere.
Any thoughts? Suggestions of where I could take it in South East Melbourne to get sorted?
Cheers, Jake.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 23d
almost any ford specialist is the way to go... but G&J should have been able to diagnose it, realistically. Sounds like diff slop or CV's, if the wheels can move backwards/forwards like that...
  • XR50T
  • Member For: 12y 1m 1d
Trutracs have slack in them. They only lock when they're being driven forward. Even engine braking or coasting unlocks them.
  • Bronze Donating Members
  • Member For: 8y 9m 18d
Yeah they do have a bit of slack but not much at all. Should not be able to free move wheels but I may be reading to much into it
take it to a driveline specialist rather than a mechanic. Usually a gearbox/driveline guy is best (I’ve found)
Thanks guys.
OK - I will take it to a driveline place, and see if they can diagnose where the slack is coming from. Any recommendations in Melbourne South-East ?
Cheers, Jake.
