  • New Member
  • Member For: 1y 29d
G'day,
Do you need both of these, or just one? Can only see one pair in your photos.
Raceworks ZF transmission adaptor (pack of 2) (RWF-922-ZF-08BK)– Aeroflow, Speedflow, Proflow all do these as well.(You need the ones for the ZF transmission, not the Ford 6R variant – outside diameter of the ZF fitting is 16.4mm)
Aeroflow -8 AN to 3/8” barb right angle adaptors (x2) (AF413-08-06BLK) – again lots of equivalents in various brands
I'm not using a fan, im just intending to go transmission, hoses, cooler mounted in front of the rad.
Cheers :)
  • Member For: 10y 14d
I *think* my info above might be incorrect based on some photos I can find.
Yes you need two fittings if you are just using normal trans hose. One fitting is for the ZF but it looks like that is already 90 degree. Then you need to adapt the AN -8 male end of that ZF fitting to a 3/8 male barb.
I think above I have details of a 90 degree adaptor for the second part, but it is a straight adaptor you need. So a -8 AN female to 3/8 barb male straight adaptor. Unfortunately I don't have the car to confirm.
  • New Member
Cheers, this is my cart... add hose, rad zip ties and gulf western atf, filter and gasket and I think im sorted.
Edited by SirFaffer
  • Like 2
  • Member For: 5y 3m 16d
Expand
Cancel that order mate
Call Driveline for filter, oil and gasket (08) 8294 4342
Call MJ products for the cooler kit (03) 9702-4880
Edited by BarraT
