cat007 Member 236 Member For: 6y 9m 28d Posted 02/08/19 12:57 AM Share Posted 02/08/19 12:57 AM Ah - oops I misread your item description. Not sure how I missed that! It appears the only difference between the Derale 25782 and 15782 is the addition of the 2 barbed fittings on the 15782 kit. Yeah the cooler is a bit bigger than the one you're using. I'll get under the car and take some measurements this weekend to see if such a thing will fit in the same spot like you've done as that looks like a great place - out of the way and short oil lines! Rubber mount the cooler? How come? Because of the fan vibration/noise or? CheersHunt Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1686637 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 9m 28d Posted 05/08/19 04:15 AM Share Posted 05/08/19 04:15 AM Doesn't look like that cooler will fit - 34x23cm is just a bit too big. How did you build your bracket? And where have you mounted it to? Have you mounted it to the chassis rail only? Or is there also a fixture point above the cooler that I can't see from the pics? Cheers! Hunt Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1686817 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 9m 28d Posted 20/08/19 01:39 AM Share Posted 20/08/19 01:39 AM On 23/07/2019 at 11:49 PM, arronm said: Hi Aaron. Couple of questions. That mounting bracket you've used, what and where is that from? It looks like a great fit. And have you bolted it to the chassis rail one on side only? Or is there a bracket up top that we just can't see? And in the left of that pic (towards the front of the car) it looks like there is a notch cut out in something that's going straight up. Is that just camera trickery or what is that? Cheers!Hunt Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1687560 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 6d Gender: Male Location: Perth Posted 20/08/19 07:48 AM Share Posted 20/08/19 07:48 AM Custom made buy Nizpro. I didn't fit it. But yes it's bolted on the side to the chassis. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1687565 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 9m 28d Posted 24/09/19 05:32 AM Share Posted 24/09/19 05:32 AM The smaller cooler and fan/thermostat from Aeroflow is not available for a few months. Looking at this but it might be a bit big to fit in that gap in the trans trunnel? https://www.ebay.com.au/itm/Aeroflow-AF72-6001-13-5-X-9-Comp-Transmission-Oil-Cooler-120w-Fan-Switch-10AN/132381548219?epid=8034416803&hash=item1ed28e1ebb:g:ebkAAOSw4DJYkV6o Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1688682 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 12y 1d Gender: Male Posted 25/09/19 11:47 PM Share Posted 25/09/19 11:47 PM Going the stand alone option for trans & oil coolers will likely be the way to go in the future. I've just been through the proper I <3 Bananas around with the plastic thermo valve for the trans, no kits available. And my ute becomes a bit of a slug in the heat, the more effective cooling you can give them, the better. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1688738 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 10d Gender: Male Location: Canberra ACT Posted 18/11/19 12:04 AM Author Share Posted 18/11/19 12:04 AM Finally finished this one off on the weekend - had been waiting until I needed to dump the coolant anyway before removing the heat exchanger from the cooling system.1. Remove one of the coolant lines from the heat exchanger and allow the coolant to drain (remove the bung from the radiator too if you are planning on a full coolant change)2. Remove the second coolant line3. Unbolt the heat exchanger from the side of the engine and throw it in the bin.4. Remove the short hose that runs from the heat exchanger to the block. At the block end, there's a 90 degree plastic fitting with one of those connections where you push the hose further on, push the side tabs in, then pull back. It is a bit of a pain - you can unplug the smaller starter motor wire to get some more access for your fingers.5. Once you have this length of hose removed, pry open the oetiker clamp holding the hose to the plastic fitting6. Re-using a hose clamp, connect the other coolant line to the plastic fitting, and refit to the side of the block. So basically you have removed the heat exchanger and the short piece of hose.7. Refill with coolant 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1689971 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,584 Member For: 17y 2m 23d Gender: Male Location: Melbourne Posted 18/11/19 12:38 AM Share Posted 18/11/19 12:38 AM Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1689973 Share on other sites More sharing options...
GeorgeGhia New Member 9 Member For: 9y 4m 7d Posted 22/02/20 07:21 AM Share Posted 22/02/20 07:21 AM (edited) Brilliant write up and excellent work, well done👏, El Andrew. Great taste in beer too I see🇦🇺👍 Cheers, George Edited 22/02/20 07:31 AM by GeorgeGhia 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1692481 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 10d Gender: Male Location: Canberra ACT Posted 22/02/20 09:34 AM Author Share Posted 22/02/20 09:34 AM Thanks mate! A year on and it's all still working nicely which is good. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/5/#findComment-1692483 Share on other sites More sharing options...
