Bulletime Donating Members 937 Member For: 14y 3m 27d Gender: Male Posted 24/07/19 10:43 AM Share Posted 24/07/19 10:43 AM If you have an extra set of hands you could take off the bonet at the track. Bit of a mad max look but would definitely be cooler Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686420 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 2d Posted 24/07/19 12:03 PM Share Posted 24/07/19 12:03 PM Haha this isn't roadkill! I think I'll look into mounting both on either side of the trans tunnel, if there's room. Slightly off topic, but, engine oil cooler running off an oil filter adapter and an inline thermostat - any recommendations? Or will an eBay one be ok? Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686423 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 3m 27d Gender: Male Posted 24/07/19 12:27 PM Share Posted 24/07/19 12:27 PM My tuna put in a setrab one but it’s too small and doesn’t have a fan. I’m a fan of derale coolers, I have a 25 row hypercooler in for the transmission with a pretty thick core and it’s awesome, I also have a pwr heat exchanger in line (did this years ago to avoid the milkshake) and I live in Canberra so want it getting up to temp https://derale.com/products/fluid-coolers/universal/remote-mount2013-10-28-09-53-271073910258/13-row-plate-fin-engine-oil-cooler-kit-with-spin-on-adapter-detail. They now have a racing line and it’s even thicker, it’ll be a tight squeeze but I’ll be upgrading to this soon with a thermostatic fluid control to only let it go through the cooler once it’s up to temp and fan also thermostatically controlled. https://derale.com/product-footer/fluid-coolers/engine/remote-mount/65860-detail Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686424 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 2d Posted 24/07/19 01:01 PM Share Posted 24/07/19 01:01 PM Woah those Derale coolers are pricey! I like the idea of a thermostatic fluid control/bypass to allow the oil to get to temp fast. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686425 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 9d Gender: Male Location: Perth Posted 24/07/19 02:08 PM Share Posted 24/07/19 02:08 PM Part 15782 (derale) and the this cooler with fan (B& M) This is what I run in My BA F6. https://derale.com/product-footer/filtration/engine2013-10-28-09-53-27459934969/sandwich-adapters https://www.holley.com/products/cooling/oil_and_transmission_coolers/supercoolers/parts/70298 Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686427 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 2d Posted 24/07/19 02:18 PM Share Posted 24/07/19 02:18 PM Brilliant - thanks heaps for that. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686428 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 2d Posted 01/08/19 06:22 AM Share Posted 01/08/19 06:22 AM On 24/07/2019 at 2:08 PM, arronm said: Part 15782 (derale) and the this cooler with fan (B& M) This is what I run in My BA F6. https://derale.com/product-footer/filtration/engine2013-10-28-09-53-27459934969/sandwich-adapters https://www.holley.com/products/cooling/oil_and_transmission_coolers/supercoolers/parts/70298 Expand Hi Aaron, In the process of deciding on and ordering the cooler. Thinking of this style adapter: https://derale.com/product-footer/filtration/engine2013-10-28-09-53-27459934969/sandwich-adapters/standard-engine-spin-on-adapter-with-1-2-npt-ports-22x1-5mm-filter-thread-detail I like it as it has a built in thermostat to allow faster heating up of the oil and better temp control when it's at lower temps? And for the cooler I'm looking at this one. Seems to be much of the same same: https://www.aeroflowperformance.com/af72-6000-13-5-x-9-comp-trans-cooler Should do the job? Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686623 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 9d Gender: Male Location: Perth Posted 01/08/19 11:57 AM Share Posted 01/08/19 11:57 AM Same same. Sandwich plate I posted has thermostat. The fan and cooler you posted is larger. I would stick with B&M. Quality will be superior 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686632 Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 8m 2d Posted 01/08/19 12:28 PM Share Posted 01/08/19 12:28 PM It doesn't have a bypass thermostat. It has a fan controller thermostat.The one I posted has a bypass thermostat which allows the oil to bypass the cooler to heat the oil faster. Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686633 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 9d Gender: Male Location: Perth Posted 01/08/19 02:19 PM Share Posted 01/08/19 02:19 PM (edited) I think you are confused. The bypass is in the sandwich plate both items posted have the bypass at 82C (180F). The coolers have a built in electrical thermostat (bi-metal switch) that can switch the fan on at 80c. Both setups you posted and I posted are nearly identical. Your cooler and fan are bigger.. Dont forget to rubber mount it... Edited 01/08/19 02:25 PM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/94598-zf-external-cooler-install-and-transmission-service-how-to/page/4/#findComment-1686634 Share on other sites More sharing options...
