sixman Donating Members 601 Member For: 20y 9m 14d Gender: Male Location: Hills District, NSW Posted 30/01/19 07:16 AM Share Posted 30/01/19 07:16 AM I keep getting a flat battery when not using the car for >24hrs. No lights etc. are on. Disconnected the battery for a few days, then reconnected and all good, so worked out the battery itself is holding charge and is ok - measured Voltage which was stable. Checked battery draw with car locked and off for >20 mins and iam seeing a 0.53A draw. Pulled fuses sequentially in engine bay and next in cabin, but none of the circuits identify the battery draw. Is this a faulty alternator? Where else do I look? Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 5d Gender: Male Location: Adelaide Posted 30/01/19 07:22 AM Share Posted 30/01/19 07:22 AM What model ? Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672628 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 2m 10d Gender: Male Location: Frankston, 3199 Posted 30/01/19 07:28 AM Share Posted 30/01/19 07:28 AM Following this - similar issue - battery scans ok, have gone through 3 new ones but still have similar issues (has never been flat, but one day it doesn't start 1st try, others it does) Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672629 Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 8m 21d Posted 30/01/19 07:34 AM Share Posted 30/01/19 07:34 AM did you do anything for it to start draining or just happened? checked all your earths? namely the ones in the engine bay as a start Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672631 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 9m 14d Gender: Male Location: Hills District, NSW Posted 30/01/19 07:50 AM Author Share Posted 30/01/19 07:50 AM Its an fg mk2 xr6t. Yeah, just started happening. Checked all the grounds and they are in good shape. I replaced the main ground wires about 18 months ago as they were deteriorating - turning to dust on the inside of the plastic shielding, but this issue is only happening in the last couple of months Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672636 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 2m 10d Gender: Male Location: Frankston, 3199 Posted 30/01/19 07:56 AM Share Posted 30/01/19 07:56 AM Anything like a dash cam or anything? Anything plugged into the USB in the centre console (charger works there when the car is off) etc Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672638 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 9m 14d Gender: Male Location: Hills District, NSW Posted 30/01/19 08:22 AM Author Share Posted 30/01/19 08:22 AM No dashcam. I have removed my usb charger and even tried removing the fuse for it. I thought all battery draw must go through the fuses, so puzzled I couldnt isolate the culprit circuit. I have a Kayhan head unit, and there was a can bus issue related to the door lock, but they fixed that with an update. I have checked the ICC and bcm circuits and no issue there. Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672641 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 2m 10d Gender: Male Location: Frankston, 3199 Posted 30/01/19 08:49 AM Share Posted 30/01/19 08:49 AM Did it only start after the Kayhan? Have you got the original version that shuts off and needs 40 secs to start or the newer one that starts quick? Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672643 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 9m 14d Gender: Male Location: Hills District, NSW Posted 30/01/19 09:08 AM Author Share Posted 30/01/19 09:08 AM Started before. Original version with longer boot up time. Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672646 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 9m 14d Gender: Male Location: Hills District, NSW Posted 02/02/19 12:14 AM Author Share Posted 02/02/19 12:14 AM Still cant work out the cause of this parasitic battery drain. Any recommendations for a autoelectrician in the hills district / parramatta area? Link to comment https://www.fordxr6turbo.com/forum/topic/94561-unexplained-battery-drain/#findComment-1672919 Share on other sites More sharing options...
