Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 13d Gender: Male Location: Adelaide Posted 26/01/19 04:45 AM Share Posted 26/01/19 04:45 AM Gave the car a punch through to 3rd gear and when I got off the pedal my brother was behind me and said a cloud of white smoke came out the exhaust. Is it to much fuel. Or is it to lean or something else I need to worry about. Cheers lads. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 10m 25d Gender: Male Location: Frankston, 3199 Posted 26/01/19 04:55 AM Share Posted 26/01/19 04:55 AM First time in a while you've given it the load, or would it be puffing every time? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,061 Member For: 9y 11m 21d Gender: Male Location: South Australia Posted 26/01/19 04:58 AM Share Posted 26/01/19 04:58 AM Did someone say Puff? Too much fuel makes black smoke. Lean makes no smoke. Burning oil or coolant makes white smoke. 1 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 13d Gender: Male Location: Adelaide Posted 26/01/19 05:40 AM Author Share Posted 26/01/19 05:40 AM Yeah doing some other reading on other forums. Maybe coolant as it leaks some but cant find it. So probably a stuffed gasket. It still making power and drives really well. If it was a bugged head it would run like sh!t yeah. 1 hour ago, Rab said: First time in a while you've given it the load, or would it be puffing every time? Na man heavy foot plenty of times. 1 Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,061 Member For: 9y 11m 21d Gender: Male Location: South Australia Posted 26/01/19 06:14 AM Share Posted 26/01/19 06:14 AM Does it use any oil at all? Worn valve guides or valve guide seals can cause your symptoms. Is there any smoke at startup? You'd need to be outside to watch it as it can clear up very quickly. If you're going through coolant then that could also be the cause of the smoke. An engine can still run great with serious problems, until they progress to the point of causing drivability issues. If you think that it's burning coolant, there is a test you can do to find out if there is combustion gasses in the cooling system. If it is a one off event then don't worry about it until it becomes more of an issue. If you suspect a leaking head then check your oil and coolant daily for contamination. Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 13d Gender: Male Location: Adelaide Posted 26/01/19 06:49 AM Author Share Posted 26/01/19 06:49 AM Coolant is clean. Doesn't burn oil. Can notice some coolant on the ground but I cant find a leak. Going to do a pressure test Monday. No smoke on start up also. Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,061 Member For: 9y 11m 21d Gender: Male Location: South Australia Posted 26/01/19 06:56 AM Share Posted 26/01/19 06:56 AM Well you've got a few ideas now mate and one problem you've mentioned with the coolant so let us know how it progresses. It could be turbski seal related but yeah, it's all just a bunch of stuff that you gotta check ay. Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 13d Gender: Male Location: Adelaide Posted 26/01/19 07:33 AM Author Share Posted 26/01/19 07:33 AM Better not be a turbo seal. I <3 Bananaser has only done 7000k. If the turbo again I'm burning the kunt and buying and 335 xr8 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 19d Gender: Male Location: Adelaide Posted 26/01/19 08:20 AM Share Posted 26/01/19 08:20 AM Is the top radiator hose harder than usual at running temp ? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,061 Member For: 9y 11m 21d Gender: Male Location: South Australia Posted 26/01/19 08:50 AM Share Posted 26/01/19 08:50 AM 1 hour ago, Bizkets is Drunk? said: Better not be a turbo seal. I ❤️ Bananaser has only done 7000k. If the turbo again I'm burning the kunt and buying and 335 xr8 Eh probably not then. Just giving some ideas to check mate. Link to comment Share on other sites More sharing options...
