  • Member For: 12y 8m 29d
Now...I know this could be anytime but on average how long does a ba xr6t engine last?
Mines a 2004 that now has 330 000 on clock. Prety much only this mechanically and driveline specific that's still stock is the actual engine
There have been a few things changed on engine such as:
Coils
Vct sensors
Timming chain and guides
All gaskets besides head and sump
Vatious sensors
But was wondering on stock boost levels how many ks people got from them
It still has plenty of go and does not make noise...it did have a lifter tap at startup but has since gone after engine flush and slightly thicker oil.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 11d
They last as long as you regularly service them and maintain the parts that wear out. The block and rotating assembly can last a huge amount of time.
  • Bronze Donating Members
  • Member For: 11y 9m 19d
Thinking any barra motor will have issues with sensors, coils, leaks, electrical riff raff, etc etc.
If the question is more around turbo specific engines, I'd say the turbo itself, maybe rings (blow by) and conn rod bearings.   How long though? well, I've seen 600K taxi's that kick on ok.   That said, they get plenty of love.   A poorly maintained barra? Not sure.    All this said, I've seen 250k on an NA block, STOCK FILTER & oil.  Still ran fine.
  • XR50T
  • Member For: 11y 11m 19d
I'd be refreshing it every 100-150k if it's leant on a fair bit. Bearings, gaskets, timing gear worth checking too.
  • To Loud
  • Member For: 13y 4m 21d
speaking of Taxi's. One of the WA members that no longer is on her, Phillmeup had 3 taxi's. they were constantly on the road. only time they stopped was to go in for a service.
They got serviced every 10,000km religiously.
Apparently he had one of the taxi's clock up 1.5 million km. I heard of another taxi doing 3.2million km.
They are a work horse and need to be looked after. I know that they are not the turbo's but still.
I was actually going to mention that.   When I met him he was getting rid of a motor that had spat a set of bearings at 450k.   Being the inquisitive guy he is he pulled it down and I think posted a comment on it somewhere.   But yes, fastidiously kept everything looking good.  Phil was the boss
  • skids
  • Member For: 12y 3m 23d
  • Gender: Not Telling
@PhilMeUp
okay the forum won't let me type anything after tagging him even when I try edit....I might send phil a txt and ask how his F6 is going (not sure if he still had the two F6 utes?)
Edited by skidxr6t
2, Was talking about buying a 3rd when I met him I think.  Or had on sold one.
  On 29/01/2019 at 9:46 AM, OZYWALKER said:
What happened to phil?
Had a decent go that bloke.
Expand
I know he was on the cusp with Uber and dealing with industry regulation change which was causing him some frustration.  To his credit he did everything by the book legally & mechanically.
  • To Loud
I believe that the ute has been registered as he got his engineering certificate.
He stopped frequenting the antilag and ford forums as he got slaughtered for having a go at the bloke that crashed into his taxi.
He was under a lot of stress at the time due to finances and the industry regulation changes.
He said he won't be coming back after all the sh*t he got for that incident. I see why a lot of people gave him sh*t and he shouldn't have done it, but the whole incident put him more into debt. I believe he is still with swan taxi's though.
