Gh0stk1ll3r Member 25 Member For: 6y 3m 9d Posted 27/01/19 05:58 AM Author Share Posted 27/01/19 05:58 AM Hi everyone, project is going well, getting close to firing it up. Just checking what I need to do to safeguard my gear pre tune? Like run the NA MAF, injectors and bypass the turbo? All this is very new to me, I'm clueless when it comes to turbos. My tuner is an hours drive away, and im hoping I can drive it there, but I'll trailer it if I have to. Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1672218 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,457 Member For: 17y 21d Gender: Male Location: Melbourne Posted 27/01/19 06:04 AM Share Posted 27/01/19 06:04 AM there's no MAF, it's a T-MAP sensor; Temperature, Manifold Air Pressure. But you cannot run the "turbo" T-MAP at all with an N/A tune. The T-MAP sensors themselves are not interchangeable at all, physically, either, as they are different pin configurations. You'll either have to run the stock injectors and T-MAP and not boost it while you drive there, or trailer it. Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1672227 Share on other sites More sharing options...
Gh0stk1ll3r Member 25 Member For: 6y 3m 9d Posted 27/01/19 07:09 AM Author Share Posted 27/01/19 07:09 AM Ok perfect thanks very much. Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1672273 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m Posted 10/02/19 04:09 PM Share Posted 10/02/19 04:09 PM On 22/01/2019 at 2:05 AM, k31th said: my only question is, why does it have a BA motor in there? somebody's a fair dinkum cheapskate to blow up a BF motor then replace it with a cheapy BA motor... Hey hey now, my cheapy BA is going to be sweet. Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1673908 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,457 Member For: 17y 21d Gender: Male Location: Melbourne Posted 10/02/19 10:34 PM Share Posted 10/02/19 10:34 PM un-opened Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1673914 Share on other sites More sharing options...
Gh0stk1ll3r Member 25 Member For: 6y 3m 9d Posted 11/02/19 07:00 AM Author Share Posted 11/02/19 07:00 AM @k31th Should have the project ready to turn key by this weekend. I have hopefully one last question. I have to incorporate boost control into my N/A loom. Would I be best to splice the boost control wiring from the BA XR6T into the BF N/A loom, pull the loom out and replace with BF XR6T loom or run an aftermarket Boost Control. Thanks for all your help, it's very much appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1673935 Share on other sites More sharing options...
Gh0stk1ll3r Member 25 Member For: 6y 3m 9d Posted 21/02/19 03:14 AM Author Share Posted 21/02/19 03:14 AM Build update. Car is running and driving. All the gear from the Turbo has been installed save for the NA ZF 6Speed, PCM and engine loom. Boost is controlled by a GFB GForce 3. 3.46 LSD at the back. Tuning is just around the corner. Pics to come. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1675460 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,457 Member For: 17y 21d Gender: Male Location: Melbourne Posted 21/02/19 03:18 AM Share Posted 21/02/19 03:18 AM Link to comment https://www.fordxr6turbo.com/forum/topic/94543-head-scratcher-what-ecu-do-i-use/page/3/#findComment-1675461 Share on other sites More sharing options...
