  • New Member
  • Member For: 6y 4m 13d
Hi guys, sorry if this has been covered in someway but I have searched everywhere.. Ive been reading a few people have wired up there boost guage to the cig lighter on FG xr6turbo with no issues. I've purchased a SaaS boost gauge from Autobarn which has 3 wires.
White=12v dash lighting
Black =negative/ground
Orange= connect to battery.
This is what's on the instructions of the guage.
The cig lighter has 2 wires..
Black =negative
Blue= power
My question is where is everyone connecting the third (orange) wire. Are they running it to the battery seperate?
I have spoken to SaaS and they said the orange must run to a  constant power source or direct to battery. The cig lighter isn't the best spot to connect it too.
How has everyone else do it..
Thanks
Edited by Adrian G
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 5d
so it has a memory function? e.g. it needs constant power to save something?
if so, then you can run a wire to the aux/tel plugs underneath the dash to get constant power. (it's a 2x4-pin plugs and easy enough with a multi-meter to find the constant source.)
  • New Member
Yes exactly right. The function is to save whatever colour you have chosen.
I can try that, otherwise worse case I guess I'll have to extend the orange wire and run it straight to the battery
  • Site Developer
the way I described has all you need for a full head-unit's power (ground, constant power, switched power, plus one extra), so it'll definitely work for a gauge :)
  • New Member
Sorry im a bit new to all this, so I can run the orange wire to the extra port on that 2x4 plug? No splicing into any other wires?
  • Site Developer
it's 2 plugs, with 4 pins in each white loom-plug. it's easy enough to just crimp on a connector and plug it straight into the port available. No need to splice any other wires at all.
  • Member For: 10y 3m 15d
  • Gender: Not Telling
Expand
I did this to power my wideband but it didn't like it and blew a fuse. Are the fuses in the usual spots or are they somewhere funky?
  • Site Developer
usual spot just below the steering wheel. might need to make it a couple more amps if you're running anything intense. I've run a head-unit off the aux one plenty of times and never blown a fuse. :idunno:
