CCCC miso xr6 Donating Members 317 Member For: 16y 4m 5d Posted 01/01/19 06:28 AM Share Posted 01/01/19 06:28 AM (edited) Hi everyone, does anyone know were I could buy a alternator that has at least 130amp for a ba falcon xr6 turbo sedan, I do know fg have 130amp but there a 3pin while ba are 2 pin. Has anyone modded a fg alternator to suit ba? Reason I ask is the car is suffering bit of voltage issues were my car drops dangerous amount of voltage while running, I run 3 pumps and a few other accessories and I know these sapp some amps. Edited 01/01/19 06:31 AM by CCCC Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,406 Member For: 17y 4d Gender: Male Location: Melbourne Posted 01/01/19 07:03 AM Share Posted 01/01/19 07:03 AM hmm, sorry, can't help you directly, but I'd be very interested to hear how you get it done, when/if it gets done. my guess would be talk to a auto-electrician about it. Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/#findComment-1668968 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 20d Gender: Male Location: Central Queensland Posted 01/01/19 07:43 AM Share Posted 01/01/19 07:43 AM In tried using a 2 wire, 160 amp alternator from a Ford Mercury. The fitment was fine, but I had issues with overcharging at high rpm. I believe that it got to around 17 volts at 6,500 rpm. I thought that it may have had a faulty regulator, so I replaced it and tried again. The overcharge remained and I was fortunate that it only blew the headlight bulbs. After this, I decided to refit the factory unit while I sorted the rest of the car. Unfortunately, I haven't got back to it.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/#findComment-1668972 Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 4m 5d Posted 01/01/19 07:58 PM Author Share Posted 01/01/19 07:58 PM I will let you guys know if some how I can get the fg alternator to work, thanks @HI PSI for your reply as I now know not to push amps that high now. Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/#findComment-1668996 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 20d Gender: Male Location: Central Queensland Posted 03/01/19 09:18 AM Share Posted 03/01/19 09:18 AM I don't think that it is an amperage issue. More likely an over speeding of the alternator. Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/#findComment-1669176 Share on other sites More sharing options...
Hunter99 New Member 10 Member For: 3y 8m 6d Posted 08/08/21 01:19 AM Share Posted 08/08/21 01:19 AM Does anyone know if you can fit a ba alternator (2 pin plug) into a bf xr6 falcon with the 3 pin plug will it cause any issues if I just make a adaptor or something... Link to comment https://www.fordxr6turbo.com/forum/topic/94490-high-amp-alternator-for-ba-falcon/#findComment-1706645 Share on other sites More sharing options...
