danger New Member 23 Member For: 11y 9m 3d Posted 04/01/19 10:48 PM Author Share Posted 04/01/19 10:48 PM If one was to use a twin in tank arrangement, would it matter if you used walbro "high pressure" 460 pumps as opposed to normal 460s? And Jet, yes I will let my tuner supply and fit, I have trouble changing a tyre....haha. Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/4/#findComment-1669257 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 14d Gender: Male Location: Adelaide Posted 04/01/19 11:27 PM Share Posted 04/01/19 11:27 PM A fuel system needs to suit a power goal with some factors included into the equation but it’s easier if you Pick a realistic end power goal ( This will Typically influence boost levels ) Pick the grade of fuel you want to use ( clearly this is a big factor for supply ) Pick the budget you want to work to ( no brainer why I’ve asked this ) Choose if it’s going to be built for street Duties, Drag racing,cct racing ( one is vastly different to the others ) A single change in any of the above can dramatically change your vehicles requirements....... Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/4/#findComment-1669258 Share on other sites More sharing options...
